Create a new broadcast domain
POST /network/ethernet/broadcast-domains
Introduced In: 9.6
Creates a new broadcast domain.
Required properties
name- Name of the broadcast-domain to create. -
mtu- Maximum transmission unit (MTU) of the broadcast domain.
Recommended optional properties
ipspace.nameoripspace.uuid- IPspace the broadcast domain belongs to.
Default property values
If not specified in POST, the following default property values are assigned:
ipspace- Default
Related ONTAP commands
network port broadcast-domain create
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
ipspace  |
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.  |
mtu  |
integer  |
Maximum transmission unit, largest packet size on this network  |
name  |
string  |
Name of the broadcast domain, scoped to its IPspace  |
ports  |
array[ports]  |
Ports that belong to the broadcast domain  |
uuid  |
string  |
Broadcast domain UUID  |
Example request
  "ipspace": {
    "name": "exchange",
  "mtu": "1500",
  "name": "bd1",
  "ports": [
      "name": "e1b",
      "node": {
        "name": "node1"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1377267  |
The specified IPspace does not exist.  |
1967082  |
The specified ipspace.name does not match the IPspace name of ipspace.uuid.  |
1967102  |
A POST operation might have left the configuration in an inconsistent state. Check the configuration.  |
53281982  |
The specified broadcast domain name is reserved by the system.  |
href  |
string  |
_links
ipspace
name  |
string  |
IPspace name  |
uuid  |
string  |
IPspace UUID  |
node
name  |
string  |
Name of node on which the port is located.  |
ports
Port UUID along with readable names
name  |
string  |
node  |
uuid  |
string  |
broadcast_domain
Set of ports that will receive a broadcast Ethernet packet from any of them
ipspace  |
mtu  |
integer  |
name  |
string  |
ports  |
array[ports]  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
