REST API reference
Create a new broadcast domain
Creates a new broadcast domain to define a network layer for communication within a specific IPspace. This is useful for organizing network traffic and managing network resources effectively.
HTTP method and endpoint
POST /network/ethernet/broadcast-domains
Introduced in
ONTAP 9.6
Required properties
  • name - Name of the broadcast-domain to create.
  • mtu - Maximum transmission unit (MTU) of the broadcast domain.
  • ipspace.name or ipspace.uuid - IPspace the broadcast domain belongs to.
Default property values
If not specified in POST, the following default property values are assigned:
  • ipspace - Default
  • network port broadcast-domain create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_links
_links
ipspace
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.
mtu
integer
Maximum transmission unit, largest packet size on this network
name
string
Name of the broadcast domain, scoped to its IPspace
ports
array[ports]
Ports that belong to the broadcast domain
uuid
string
Broadcast domain UUID
Example request
  "ipspace": {
    "name": "exchange",
  "mtu": 1500,
  "name": "bd1",
  "ports": [
      "name": "e1b",
      "node": {
        "name": "node1"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1377267
The specified IPspace does not exist.
1967082
The specified ipspace.name does not match the IPspace name of ipspace.uuid.
1967102
A POST operation might have left the configuration in an inconsistent state. Check the configuration.
53281982
The specified broadcast domain name is reserved by the system.
string
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
node
name
string
Name of node on which the port is located.
ports
Port UUID along with readable names
_links
_links
name
string
node
node
uuid
string
broadcast_domain
Set of ports that will receive a broadcast Ethernet packet from any of them
_links
_links
ipspace
ipspace
mtu
integer
name
string
ports
array[ports]
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
