Adds one or more initiators to an initiator group
required properties
nameorrecordsname- initiator name(s) to add to the initiator group # related ontap commands -
lun igroup add# learn more -
doc /protocols/san/igroups](#docs-san-protocols_san_igroups)
POST /protocols/san/igroups/{igroup.uuid}/initiators
Introduced In: 9.6
Adds one or more initiators to an initiator group. This API does not support adding initiators to an initiator group that already contains nested initiator groups.
Required properties
nameorrecords.name- Initiator name(s) to add to the initiator group.
Related ONTAP commands
lun igroup add
Learn more
igroup.uuid |
string |
path |
True |
The unique identifier of the initiator group. |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
A comment available for use by the administrator. Valid in POST and PATCH. |
connectivity_tracking |
Overview of the initiator's connections to ONTAP.
igroup |
The initiator group in which the initiator is found. Note that this does not mean that the initiator cannot also be found in other initiator groups. |
name |
string |
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the An FC WWPN consists of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters. |
records |
array[records] |
An array of initiators specified to add multiple initiators to an initiator group in a single API call. Not allowed when the |
Example request
"comment": "string",
"connectivity_tracking": {
"alerts": [
"summary": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"connection_state": "string",
"connections": [
"logins": [
"interface": {
"fc": {
"name": "fc_lif1",
"uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
"wwpn": "20:00:00:50:56:b4:13:a8"
"ip": {
"name": "lif1",
"last_seen_time": "2021-03-14T05:19:00Z"
"node": {
"name": "node1",
"igroup": {
"name": "igroup1",
"name": "iqn.1998-01.com.corp.iscsi:name1",
"records": [
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[igroup_initiator] |
"num_records": 1,
"records": [
"alerts": [
"summary": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"connections": [
"logins": [
"interface": {
"fc": {
"name": "fc_lif1",
"ip": {
"name": "lif1",
"node": {
"name": "node1",
"igroup": {
"name": "igroup1",
"records": [
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1254193 |
Adding an initiator would cause the initiator to be mapped to the same LUN more than once. |
1254324 |
Adding an initiator would cause the initiator to have the same logical unit identifier for multiple LUN maps. |
5373969 |
A supplied initiator name looks like an iSCSI IQN initiator, but the portions after the prefix are missing. |
5373971 |
A supplied initiator name looks like an iSCSI IQN initiator, but the date portion is invalid. |
5373972 |
A supplied initiator name looks like an iSCSI IQN initiator, but the naming authority portion is invalid. |
5373977 |
A supplied initiator name looks like an iSCSI EUI initiator, but the length is invalid. |
5373978 |
A supplied initiator name looks like an iSCSI EUI initiator, but the format is invalid. |
5373992 |
A supplied initiator name was too long to be valid. |
5373993 |
A supplied initiator name did not match any valid format. |
5374033 |
Initiators must be supplied. |
5374035 |
A supplied initiator is already in the initiator group. |
5374038 |
An invalid Fibre Channel WWPN was supplied. |
5374039 |
An invalid iSCSI initiator name was supplied. |
5374734 |
An initiator is already in another initiator group with a conflicting operating system type. |
5374852 |
The initiator group specified in the URI does not exist. |
5374917 |
Multiple matching initiators have been supplied with conflicting comments. |
href |
string |
_links
code |
string |
Argument code |
message |
string |
Message argument |
summary
A user friendly message describing the connection state.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
alerts
summary |
A user friendly message describing the connection state. |
fc
An FC interface.
name |
string |
The name of the FC interface. |
uuid |
string |
The unique identifier of the FC interface. |
wwpn |
string |
The WWPN of the FC interface. |
ip
IP information
ip
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
interface
fc |
An FC interface. |
ip |
logins
connected |
boolean |
True if the initiator is currently logged in to this connection's interface. |
interface |
last_seen_time |
string |
The last time this initiator logged in. Logins not seen for 48 hours are cleared and not reported. |
node
name |
string |
uuid |
string |
connections
logins |
array[logins] |
node |
alerts |
array[alerts] |
connection_state |
string |
Connection state. |
connections |
array[connections] |
igroup
name |
string |
The name of the initiator group. |
uuid |
string |
records
comment |
string |
name |
string |
igroup_initiator
comment |
string |
igroup |
name |
string |
records |
array[records] |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
