REST API reference
Add initiators to an initiator group
Adds initiators to an initiator group. Use this operation to organize initiators within your storage network for streamlined management and access.
HTTP method and endpoint
POST /protocols/san/igroups/{igroup.uuid}/initiators
Introduced in
ONTAP 9.6
Usage notes
Adds one or more initiators to an initiator group. This API does not support adding initiators to an initiator group that already contains nested initiator groups.
Required properties
  • name or records.name - Initiator name(s) to add to the initiator group.
  • lun igroup add
igroup.uuid
string
path
True
The unique identifier of the initiator group.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
A comment available for use by the administrator. Valid in POST and PATCH.
connectivity_tracking
Overview of the initiator's connections to ONTAP.
  • readOnly: 1
  • Introduced in: 9.11
igroup
igroup
The initiator group in which the initiator is found.
Note that this does not mean that the initiator cannot also be found in other initiator groups.
name
string
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the records property is used.
An FC WWPN consists of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters.
records
array[records]
An array of initiators specified to add multiple initiators to an initiator group in a single API call. Not allowed when the name property is used.
Example request
  "comment": "string",
  "connectivity_tracking": {
    "alerts": [
        "summary": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
          "target": "uuid"
    "connection_state": "string",
    "connections": [
        "logins": [
            "interface": {
              "fc": {
                "name": "fc_lif1",
                "uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
                "wwpn": "20:00:00:50:56:b4:13:a8"
              "ip": {
                "name": "lif1",
            "last_seen_time": "2021-03-14T05:19:00Z"
        "node": {
          "name": "node1",
  "igroup": {
    "name": "igroup1",
  "name": "iqn.1998-01.com.corp.iscsi:name1",
  "records": [
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[igroup_initiator]
  "num_records": 1,
  "records": [
        "alerts": [
            "summary": {
              "arguments": [
                  "code": "string",
                  "message": "string"
              "code": "4",
              "target": "uuid"
        "connections": [
            "logins": [
                "interface": {
                  "fc": {
                    "name": "fc_lif1",
                  "ip": {
                    "name": "lif1",
            "node": {
              "name": "node1",
      "igroup": {
        "name": "igroup1",
      "records": [
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1254193
Adding an initiator would cause the initiator to be mapped to the same LUN more than once.
1254324
Adding an initiator would cause the initiator to have the same logical unit identifier for multiple LUN maps.
5373969
A supplied initiator name looks like an iSCSI IQN initiator, but the portions after the prefix are missing.
5373971
A supplied initiator name looks like an iSCSI IQN initiator, but the date portion is invalid.
5373972
A supplied initiator name looks like an iSCSI IQN initiator, but the naming authority portion is invalid.
5373977
A supplied initiator name looks like an iSCSI EUI initiator, but the length is invalid.
5373978
A supplied initiator name looks like an iSCSI EUI initiator, but the format is invalid.
5373992
A supplied initiator name was too long to be valid.
5373993
A supplied initiator name did not match any valid format.
5374033
Initiators must be supplied.
5374035
A supplied initiator is already in the initiator group.
5374038
An invalid Fibre Channel WWPN was supplied.
5374039
An invalid iSCSI initiator name was supplied.
5374734
An initiator is already in another initiator group with a conflicting operating system type.
5374852
The initiator group specified in the URI does not exist.
5374917
Multiple matching initiators have been supplied with conflicting comments.
string
code
string
Argument code
message
string
Message argument
summary
A user friendly message describing the connection state.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
alerts
summary
summary
fc
An FC interface.
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
ip
IP information
ip
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
interface
fc
fc
An FC interface.
ip
ip
logins
connected
boolean
True if the initiator is currently logged in to this connection's interface.
interface
interface
last_seen_time
string
The last time this initiator logged in. Logins not seen for 48 hours are cleared and not reported.
node
name
string
uuid
string
connections
logins
array[logins]
node
node
alerts
array[alerts]
connection_state
string
Connection state.
connections
array[connections]
igroup
name
string
The name of the initiator group.
uuid
string
records
comment
string
name
string
igroup_initiator
comment
string
  • readOnly: 1
igroup
igroup
name
string
records
array[records]
error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
