Add initiators to an initiator group
Adds initiators to an existing initiator group. This helps you manage access control for your storage resources by grouping and organizing initiators efficiently.
HTTP method and endpoint
POST /protocols/san/igroups/{igroup.uuid}/initiators
Introduced in
ONTAP 9.6
Usage notes
Adds one or more initiators to an initiator group.
This API does not support adding initiators to an initiator group that already contains nested initiator groups.
Required properties
nameorrecords.name- Initiator name(s) to add to the initiator group.
Related ONTAP commands
lun igroup add
Learn more
igroup.uuid |
string |
path |
True |
The unique identifier of the initiator group. |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
A comment available for use by the administrator. Valid in POST and PATCH. |
connectivity_tracking |
Overview of the initiator's connections to ONTAP.
igroup |
The initiator group in which the initiator is found. Note that this does not mean that the initiator cannot also be found in other initiator groups. |
name |
string |
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the An FC WWPN consists of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters. |
proximity |
Properties that define to what SVMs the initiator is proximal. This information is used to properly report active optimized and active non-optimized network paths via ALUA. If no configuration has been specified for an initiator, the sub-object will not be present in GET. These properties can be set via initiator group POST and PATCH and apply to all instances of the initiator in all initiator groups in the SVM and its peers. The |
records |
array[records] |
An array of initiators specified to add multiple initiators to an initiator group in a single API call. Not allowed when the |
Example request
"comment": "string",
"connectivity_tracking": {
"alerts": [
"connection_state": "string",
"connections": [
"logins": [
"interface": {
"fc": {
"name": "fc_lif1",
"uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
"wwpn": "20:00:00:50:56:b4:13:a8"
"ip": {
"name": "lif1",
"last_seen_time": "2021-03-14 05:19:00 +0000"
"node": {
"name": "node1",
"igroup": {
"name": "igroup1",
"name": "iqn.1998-01.com.corp.iscsi:name1",
"proximity": {
"peer_svms": [
"name": "peer1",
"uuid": "4204cf77-4c82-9bdb-5644-b5a841c097a9"
"records": [
"proximity": {
"peer_svms": [
"name": "peer1",
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[igroup_initiator] |
"num_records": 1,
"records": [
"alerts": [
"connections": [
"logins": [
"interface": {
"fc": {
"name": "fc_lif1",
"ip": {
"name": "lif1",
"node": {
"name": "node1",
"igroup": {
"name": "igroup1",
"proximity": {
"peer_svms": [
"name": "peer1",
"records": [
"proximity": {
"peer_svms": [
"name": "peer1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1254193 |
Adding an initiator would cause the initiator to be mapped to the same LUN more than once. |
1254324 |
Adding an initiator would cause the initiator to have the same logical unit identifier for multiple LUN maps. |
5373969 |
A supplied initiator name looks like an iSCSI IQN initiator, but the portions after the prefix are missing. |
5373971 |
A supplied initiator name looks like an iSCSI IQN initiator, but the date portion is invalid. |
5373972 |
A supplied initiator name looks like an iSCSI IQN initiator, but the naming authority portion is invalid. |
5373977 |
A supplied initiator name looks like an iSCSI EUI initiator, but the length is invalid. |
5373978 |
A supplied initiator name looks like an iSCSI EUI initiator, but the format is invalid. |
5373982 |
An invalid WWN was specified. The length is incorrect. |
5373983 |
An invalid WWN was specified. The format is incorrect. |
5373992 |
A supplied initiator name was too long to be valid. |
5373993 |
A supplied initiator name did not match any valid format. |
5374033 |
Initiators must be supplied. |
5374035 |
A supplied initiator is already in the initiator group. |
5374038 |
An invalid Fibre Channel WWPN was supplied. |
5374039 |
An invalid iSCSI initiator name was supplied. |
5374734 |
An initiator is already in another initiator group with a conflicting operating system type. |
5374761 |
An error was reported by the peer cluster while adding an initiator to a replicated initiator group. The specific error will be included as a nested error. |
5374852 |
The initiator group specified in the URI does not exist. |
5374917 |
Duplicated initiators have conflicting property values. |
5375055 |
The |
5375056 |
An SVM peering relationship that does not have the initiator group's SVM as the local SVM was specified. |
5375261 |
Setting initiator proximity is not supported for the SVM type. |
5376057 |
Setting initiator proximity is not supported for the ONTAP version. |
5376059 |
Setting initiator proximity to a peer that is either the destination of an SVM DR relationship or in a Metrocluster configuration is not supported. |
26345672 |
The specified SVM peering relationship was not found. |
26345673 |
An SVM peering relationship between the initiator group's SVM and specified peer SVM was not found. |
26345675 |
An SVM peering relationship UUID and name were specified and they do not refer to the same SVM peering relationship. |
26345680 |
Supplied SVM peer is on the local cluster. The operation requires a peer on a remote cluster. |
href |
string |
_links
code |
string |
Argument code |
message |
string |
Message argument |
summary
A user friendly message describing the connection state.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
alerts
fc
An FC interface.
name |
string |
The name of the FC interface. |
uuid |
string |
The unique identifier of the FC interface. |
wwpn |
string |
The WWPN of the FC interface. |
ip
IP information
ip
A network interface. Either UUID or name may be supplied on input.
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
interface
fc |
An FC interface. |
ip |
A network interface. Either UUID or name may be supplied on input. |
logins
connected |
boolean |
True if the initiator is currently logged in to this connection's interface. |
interface |
last_seen_time |
string |
The last time this initiator logged in. Logins not seen for 48 hours are cleared and not reported. |
node
name |
string |
uuid |
string |
connections
logins |
array[logins] |
node |
alerts |
array[alerts] |
connection_state |
string |
Connection state. |
connections |
array[connections] |
igroup
name |
string |
The name of the initiator group. |
uuid |
string |
peer_svms
A reference to an SVM peer relationship.
name |
string |
The local name of the peer SVM. This name is unique among all local and peer SVMs. |
uuid |
string |
The unique identifier of the SVM peer relationship. This is the UUID of the relationship, not the UUID of the peer SVM itself. |
proximity
These properties can be set via initiator group POST and PATCH and apply to all instances of the initiator in all initiator groups in the SVM and its peers. The proximity sub-object for an initiator is set in POST and PATCH in its entirety and replaces any previously set proximity for the initiator within the SVM for the initiator within the SVM. The local_svm property must always be set to true or false when setting the proximity property. To clear any previously set proximity, POST or PATCH the proximity object to null.
local_svm |
boolean |
A boolean that indicates if the initiator is proximal to the SVM of the containing initiator group. This is required for any POST or PATCH that includes the |
peer_svms |
array[peer_svms] |
An array of remote peer SVMs to which the initiator is proximal. |
records
comment |
string |
name |
string |
proximity |
igroup_initiator
comment |
string |
igroup |
name |
string |
proximity |
records |
array[records] |
returned_error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
