Create iSCSI credentials
Creates iSCSI credentials to establish secure communication between an initiator and a storage virtual machine (SVM) using the specified authentication type. This operation is essential when setting up or modifying iSCSI security configurations within your storage environment.
HTTP method and endpoint
POST /protocols/san/iscsi/credentials
Introduced in
ONTAP 9.6
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the iSCSI credentials. -
initiator- Initiator for which the iSCSI credentials are to be created. -
authentication_type- Type of authentication to use for the credentials.
Recommended optional properties
chap.inbound.user- In-bound CHAP authentication user name. -
chap.inbound.password- In-bound CHAP authentication password. -
chap.outbound.user- Out-bound CHAP authentication user name. -
chap.outbound.password- Out-bound CHAP authentication password.
Related ONTAP commands
vserver iscsi security create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
authentication_type |
string |
The iSCSI authentication type. Required in POST; optional in PATCH. |
chap |
Challenge-Handshake Authentication Protocol (CHAP) credentials. |
initiator |
string |
The iSCSI initiator to which the credentials apply. Required in POST. |
initiator_address |
Initiator address ranges. |
svm |
Example request
"authentication_type": "string",
"chap": {
"inbound": {
"password": "string",
"user": "string"
"outbound": {
"user": "string"
"initiator": "iqn.1998-01.com.corp.iscsi:name1",
"initiator_address": {
"masks": [
"address": "10.10.10.7",
"netmask": "24"
"ranges": [
"end": "10.10.10.7",
"start": "10.10.10.7"
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[iscsi_credentials] |
"num_records": 1,
"records": [
"chap": {
"inbound": {
"user": "string"
"outbound": {
"user": "string"
"masks": [
"netmask": "24"
"ranges": [
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
An SVM with the specified UUID does not exist. |
2621706 |
Both the SVM UUID and SVM name were supplied, but they do not refer to the same SVM. |
2621707 |
No SVM was specified. Either |
5373969 |
A non-empty qualifier is required after the prefix. An example of a valid IQN is iqn.1995-08.com.example:string. |
5373970 |
The IQN prefix is invalid. The correct IQN prefix is iqn. An example of a valid IQN is iqn.1995-08.com.example:string. |
5373971 |
The date field is invalid. A valid date field is yyyy-mm. An example of a valid IQN is iqn.1995-08.com.example:string. |
5373972 |
The naming authority and string fields can contain only the characters a-z, 0-9, ., :, and -. |
5373977 |
The EUI-64 identifier field must be exactly 16 hexadecimal digits. |
5373978 |
The EUI formatted initiator name supplied is invalid. A valid EUI format is eui.XXXXXXXXXXXXXXXX, where X is a hexadecimal digit. |
5373997 |
The initiator name supplied in invalid. The valid initiator name formats are iqn.1995-08.com.example:string or eui.0123456789abcdef. |
5374078 |
The iSCSI service does not exist. |
5374142 |
An iSCSI security credential already exists for the specified initiator. |
5374145 |
The iSCSI security password must contain an even number of valid hex digits. |
5374147 |
The CHAP inbound and outbound passwords must be different. |
5374149 |
The inbound user and password properties are required for CHAP authentication. |
5374150 |
Outbound CHAP authentication requires an outbound password. |
5374855 |
The value for property |
5374856 |
5374900 |
Setting the CHAP authentication properties are not supported with authentication types none or deny. |
href |
string |
_links
inbound
Inbound CHAP credentials.
password |
string |
The inbound CHAP password. Write-only; optional in POST and PATCH. |
user |
string |
The inbound CHAP user name. Optional in POST and PATCH. |
outbound
Output CHAP credentials.
To clear previously set outbound CHAP credentials, set property chap.outbound.user to an empty string in PATCH.
password |
string |
The outbound CHAP password. Write-only; optional in POST and PATCH. |
user |
string |
The outbound CHAP user name. Optional in POST and PATCH. To clear previously set outbound CHAP credentials, set this property to an empty string in PATCH. |
chap
inbound |
Inbound CHAP credentials. |
outbound |
Output CHAP credentials. To clear previously set outbound CHAP credentials, set property |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
ip_address_range
IP address range
end |
string |
start |
string |
initiator_address
masks |
array[ip_info] |
ranges |
array[ip_address_range] |
svm
name |
string |
The name of the SVM. |
uuid |
string |
iscsi_credentials
string |
chap |
initiator |
string |
initiator_address |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
