Create iSCSI credentials
Creates iSCSI credentials to enable secure communication between your iSCSI initiator and the storage virtual machine (SVM). This process is essential for establishing authenticated and encrypted connections in your storage network.
HTTP method and endpoint
POST /protocols/san/iscsi/credentials
Introduced in
ONTAP 9.6
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the iSCSI credentials. -
initiator- Initiator for which the iSCSI credentials are to be created. -
authentication_type- Type of authentication to use for the credentials.
Recommended optional properties
chap.inbound.user- In-bound CHAP authentication user name. -
chap.inbound.password- In-bound CHAP authentication password. -
chap.outbound.user- Out-bound CHAP authentication user name. -
chap.outbound.password- Out-bound CHAP authentication password.
Related ONTAP commands
vserver iscsi security create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
authentication_type |
string |
The iSCSI authentication type. Required in POST; optional in PATCH. |
chap |
Challenge-Handshake Authentication Protocol (CHAP) credentials. |
initiator |
string |
The iSCSI initiator to which the credentials apply. Required in POST. |
initiator_address |
Initiator address ranges. |
svm |
Example request
"authentication_type": "string",
"chap": {
"inbound": {
"password": "string",
"user": "string"
"outbound": {
"user": "string"
"initiator": "iqn.1998-01.com.corp.iscsi:name1",
"initiator_address": {
"masks": [
"address": "10.10.10.7",
"netmask": "24"
"ranges": [
"end": "10.10.10.7",
"start": "10.10.10.7"
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[iscsi_credentials] |
"num_records": 1,
"records": [
"chap": {
"inbound": {
"user": "string"
"outbound": {
"user": "string"
"masks": [
"netmask": "24"
"ranges": [
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
An SVM with the specified UUID does not exist. |
2621706 |
Both the SVM UUID and SVM name were supplied, but they do not refer to the same SVM. |
2621707 |
No SVM was specified. Either |
5373969 |
A non-empty qualifier is required after the prefix. An example of a valid IQN is iqn.1995-08.com.example:string. |
5373970 |
The IQN prefix is invalid. The correct IQN prefix is iqn. An example of a valid IQN is iqn.1995-08.com.example:string. |
5373971 |
The date field is invalid. A valid date field is yyyy-mm. An example of a valid IQN is iqn.1995-08.com.example:string. |
5373972 |
The naming authority and string fields can contain only the characters a-z, 0-9, ., :, and -. |
5373977 |
The EUI-64 identifier field must be exactly 16 hexadecimal digits. |
5373978 |
The EUI formatted initiator name supplied is invalid. A valid EUI format is eui.XXXXXXXXXXXXXXXX, where X is a hexadecimal digit. |
5373997 |
The initiator name supplied in invalid. The valid initiator name formats are iqn.1995-08.com.example:string or eui.0123456789abcdef. |
5374078 |
The iSCSI service does not exist. |
5374142 |
An iSCSI security credential already exists for the specified initiator. |
5374145 |
The iSCSI security password must contain an even number of valid hex digits. |
5374147 |
The CHAP inbound and outbound passwords must be different. |
5374149 |
The inbound user and password properties are required for CHAP authentication. |
5374150 |
Outbound CHAP authentication requires an outbound password. |
5374855 |
The value for property |
5374856 |
5374900 |
Setting the CHAP authentication properties are not supported with authentication types none or deny. |
href |
string |
_links
inbound
Inbound CHAP credentials.
password |
string |
The inbound CHAP password. Write-only; optional in POST and PATCH. |
user |
string |
The inbound CHAP user name. Optional in POST and PATCH. |
outbound
Output CHAP credentials.
To clear previously set outbound CHAP credentials, set property chap.outbound.user to an empty string in PATCH.
password |
string |
The outbound CHAP password. Write-only; optional in POST and PATCH. |
user |
string |
The outbound CHAP user name. Optional in POST and PATCH. To clear previously set outbound CHAP credentials, set this property to an empty string in PATCH. |
chap
inbound |
Inbound CHAP credentials. |
outbound |
Output CHAP credentials. To clear previously set outbound CHAP credentials, set property |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
ip_address_range
IP address range
end |
string |
start |
string |
initiator_address
masks |
array[ip_info] |
ranges |
array[ip_address_range] |
svm
name |
string |
The name of the SVM. |
uuid |
string |
iscsi_credentials
string |
chap |
initiator |
string |
initiator_address |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
