REST API reference
Create iSCSI credentials
Creates iSCSI credentials to establish secure connections for your storage environment. This setup is essential for defining authentication methods and ensuring secure communication with initiators.
HTTP method and endpoint
POST /protocols/san/iscsi/credentials
Introduced in
ONTAP 9.6
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the iSCSI credentials.
  • initiator - Initiator for which the iSCSI credentials are to be created.
  • authentication_type - Type of authentication to use for the credentials.
  • chap.inbound.user - In-bound CHAP authentication user name.
  • chap.inbound.password - In-bound CHAP authentication password.
  • chap.outbound.user - Out-bound CHAP authentication user name.
  • chap.outbound.password - Out-bound CHAP authentication password.
  • vserver iscsi security create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
authentication_type
string
The iSCSI authentication type. Required in POST; optional in PATCH.
chap
chap
Challenge-Handshake Authentication Protocol (CHAP) credentials.
initiator
string
The iSCSI initiator to which the credentials apply. Required in POST.
initiator_address
initiator_address
Initiator address ranges.
svm
svm
Example request
  "authentication_type": "string",
  "chap": {
    "inbound": {
      "password": "string",
      "user": "string"
    "outbound": {
      "user": "string"
  "initiator": "iqn.1998-01.com.corp.iscsi:name1",
  "initiator_address": {
    "masks": [
        "address": "10.10.10.7",
        "netmask": "24"
    "ranges": [
        "end": "10.10.10.7",
        "start": "10.10.10.7"
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[iscsi_credentials]
  "num_records": 1,
  "records": [
      "chap": {
        "inbound": {
          "user": "string"
        "outbound": {
          "user": "string"
        "masks": [
            "netmask": "24"
        "ranges": [
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
An SVM with the specified UUID does not exist.
2621706
Both the SVM UUID and SVM name were supplied, but they do not refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5373969
A non-empty qualifier is required after the prefix. An example of a valid IQN is iqn.1995-08.com.example:string.
5373970
The IQN prefix is invalid. The correct IQN prefix is iqn. An example of a valid IQN is iqn.1995-08.com.example:string.
5373971
The date field is invalid. A valid date field is yyyy-mm. An example of a valid IQN is iqn.1995-08.com.example:string.
5373972
The naming authority and string fields can contain only the characters a-z, 0-9, ., :, and -.
5373977
The EUI-64 identifier field must be exactly 16 hexadecimal digits.
5373978
The EUI formatted initiator name supplied is invalid. A valid EUI format is eui.XXXXXXXXXXXXXXXX, where X is a hexadecimal digit.
5373997
The initiator name supplied in invalid. The valid initiator name formats are iqn.1995-08.com.example:string or eui.0123456789abcdef.
5374078
The iSCSI service does not exist.
5374142
An iSCSI security credential already exists for the specified initiator.
5374145
The iSCSI security password must contain an even number of valid hex digits.
5374147
The CHAP inbound and outbound passwords must be different.
5374149
The inbound user and password properties are required for CHAP authentication.
5374150
Outbound CHAP authentication requires an outbound password.
5374855
The value for property initiator_address.ranges.start is greater than the value for property initiator_address.ranges.end.
5374856
The value for property initiator_address.ranges.start does not belong to the same IP address family as the value for property initiator_address.ranges.end.
5374900
Setting the CHAP authentication properties are not supported with authentication types none or deny.
string
inbound
Inbound CHAP credentials.
password
string
The inbound CHAP password. Write-only; optional in POST and PATCH.
user
string
The inbound CHAP user name. Optional in POST and PATCH.
outbound
Output CHAP credentials.
To clear previously set outbound CHAP credentials, set property chap.outbound.user to an empty string in PATCH.
password
string
The outbound CHAP password. Write-only; optional in POST and PATCH.
user
string
The outbound CHAP user name. Optional in POST and PATCH.
To clear previously set outbound CHAP credentials, set this property to an empty string in PATCH.
chap
inbound
inbound
outbound
outbound
ip_info
IP information
address
string
IPv4 or IPv6 address
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
ip_address_range
IP address range
end
string
start
string
initiator_address
masks
array[ip_info]
ranges
array[ip_address_range]
svm
name
string
uuid
string
iscsi_credentials
authentication_type
string
chap
chap
initiator
string
initiator_address
initiator_address
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
