REST API reference
Create or install security certificates
Creates or installs security certificates within an existing SVM, establishing secure communication channels for your applications. This function is essential for managing digital identities and encryption keys, ensuring data integrity and confidentiality in your network environments.
HTTP method and endpoint
POST /security/certificates
Introduced in
ONTAP 9.6
Usage notes
Creates or installs a certificate.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create or install the certificate.
  • common_name - Common name of the certificate. Required when creating a certificate.
  • type - Type of certificate.
  • public_certificate - Public key certificate in PEM format. Required when installing a certificate.
  • private_key - Private key certificate in PEM format. Required when installing a CA-signed certificate.
  • expiry_time - Certificate expiration time. Specifying an expiration time is recommended when creating a certificate.
  • key_size - Key size of the certificate in bits. Specifying a strong key size is recommended when creating a certificate.
  • name - Unique certificate name per SVM. If one is not provided, it is automatically generated.
Default property values
If not specified in POST, the following default property values are assigned:
  • key_size - 2048
  • expiry_time - P365DT
  • hash_function - sha256
  • security certificate create
  • security certificate install
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
authority_key_identifier
string
Provides the key identifier of the issuing CA certificate that signed the SSL certificate.
ca
string
Certificate authority
common_name
string
FQDN or custom common name. Provide on POST when creating a self-signed certificate.
expiry_time
string
Certificate expiration time. Can be provided on POST if creating self-signed certificate. The expiration time range is between 1 day to 10 years.
hash_function
string
Hashing function. Can be provided on POST when creating a self-signed certificate. Hash functions md5 and sha1 are not allowed on POST.
intermediate_certificates
array[string]
Chain of intermediate Certificates in PEM format. Only valid in POST when installing a certificate.
key_size
integer
Key size of requested Certificate in bits. One of 512, 1024, 1536, 2048, 3072. Can be provided on POST if creating self-signed certificate. Key size of 512 is not allowed on POST.
name
string
Certificate name. If not provided in POST, a unique name specific to the SVM is automatically generated.
private_key
string
Private key Certificate in PEM format. Only valid for create when installing a CA-signed certificate. This is not audited.
public_certificate
string
Public key Certificate in PEM format. If this is not provided in POST, a self-signed certificate is created.
serial_number
string
Serial number of certificate.
subject_key_identifier
string
Provides the key identifier used to identify the public key in the SSL certificate.
svm
svm
type
string
Type of Certificate. The following types are supported:
  • client - a certificate and its private key used by an SSL client in ONTAP.
  • server - a certificate and its private key used by an SSL server in ONTAP.
  • client_ca - a Certificate Authority certificate used by an SSL server in ONTAP to verify an SSL client certificate.
  • server_ca - a Certificate Authority certificate used by an SSL client in ONTAP to verify an SSL server certificate.
  • root_ca - a self-signed certificate used by ONTAP to sign other certificates by acting as a Certificate Authority.
  • enum: ["client", "server", "client_ca", "server_ca", "root_ca"]
  • Introduced in: 9.6
uuid
string
Unique ID that identifies a certificate.
Example request
  "authority_key_identifier": "26:1F:C5:53:5B:D7:9E:E2:37:74:F4:F4:06:09:03:3D:EB:41:75:D7",
  "ca": "string",
  "common_name": "test.domain.com",
  "expiry_time": "string",
  "hash_function": "string",
  "intermediate_certificates": [
    "-----BEGIN CERTIFICATE----- MIIBuzCCAWWgAwIBAgIIFTZBrqZwUUMwDQYJKoZIhvcNAQELBQAwHDENMAsGA1UE AxMEVEVTVDELMAkGA1UEBhMCVVMwHhcNMTgwNjA4MTgwOTAxWhcNMTkwNjA4MTgw OTAxWjAcMQ0wCwYDVQQDEwRURVNUMQswCQYDVQQGEwJVUzBcMA0GCSqGSIb3DQEB AQUAA0sAMEgCQQDaPvbqUJJFJ6NNTyK3Yb+ytSjJ9aa3yUmYTD9uMiP+6ycjxHWB e8u9z6yCHsW03ync+dnhE5c5z8wuDAY0fv15AgMBAAGjgYowgYcwDAYDVR0TBAUw AwEB/zALBgNVHQ8EBAMCAQYwHQYDVR0OBBYEFMJ7Ev/o/3+YNzYh5XNlqqjnw4zm MEsGA1UdIwREMEKAFMJ7Ev/o/3+YNzYh5XNlqqjnw4zmoSCkHjAcMQ0wCwYDVQQD EwRURVNUMQswCQYDVQQGEwJVU4IIFTZBrqZwUUMwDQYJKoZIhvcNAQELBQADQQAv DovYeyGNnknjGI+TVNX6nDbyzf7zUPqnri0KuvObEeybrbPW45sgsnT5dyeE/32U 9Yr6lklnkBtVBDTmLnrC -----END CERTIFICATE-----"
  "name": "cert1",
  "private_key": "-----BEGIN PRIVATE KEY----- MIIBVAIBADANBgkqhkiG9w0BAQEFAASCAT4wggE6AgEAAkEAu1/a8f3G47cZ6pel Hd3aONMNkGJ8vSCH5QjicuDm92VtVwkAACEjIoZSLYlJvPD+odL+lFzVQSmkneW7 VCGqYQIDAQABAkAcfNpg6GCQxoneLOghvlUrRotNZGvqpUOEAvHK3X7AJhz5SU4V an36qvsAt5ghFMVM2iGvGaXbj0dAd+Jg64pxAiEA32Eh9mPtFSmZhTIUMeGcPmPk qIYCEuP8a/ZLmI9s4TsCIQDWvLQuvjSVfwPhi0TFAb5wqAET8X5LBFqtGX5QlUep EwIgFnqM02Gc4wtLoqa2d4qPkYu13+uUW9hLd4XSd6i/OS8CIQDT3elU+Rt+qIwW u0cFrVvNYSV3HNzDfS9N/IoxTagfewIgPvXADe5c2EWbhCUkhN+ZCf38AKewK9TW lQcDy4L+f14= -----END PRIVATE KEY-----",
  "public_certificate": "-----BEGIN CERTIFICATE----- MIIBuzCCAWWgAwIBAgIIFTZBrqZwUUMwDQYJKoZIhvcNAQELBQAwHDENMAsGA1UE AxMEVEVTVDELMAkGA1UEBhMCVVMwHhcNMTgwNjA4MTgwOTAxWhcNMTkwNjA4MTgw OTAxWjAcMQ0wCwYDVQQDEwRURVNUMQswCQYDVQQGEwJVUzBcMA0GCSqGSIb3DQEB AQUAA0sAMEgCQQDaPvbqUJJFJ6NNTyK3Yb+ytSjJ9aa3yUmYTD9uMiP+6ycjxHWB e8u9z6yCHsW03ync+dnhE5c5z8wuDAY0fv15AgMBAAGjgYowgYcwDAYDVR0TBAUw AwEB/zALBgNVHQ8EBAMCAQYwHQYDVR0OBBYEFMJ7Ev/o/3+YNzYh5XNlqqjnw4zm MEsGA1UdIwREMEKAFMJ7Ev/o/3+YNzYh5XNlqqjnw4zmoSCkHjAcMQ0wCwYDVQQD EwRURVNUMQswCQYDVQQGEwJVU4IIFTZBrqZwUUMwDQYJKoZIhvcNAQELBQADQQAv DovYeyGNnknjGI+TVNX6nDbyzf7zUPqnri0KuvObEeybrbPW45sgsnT5dyeE/32U 9Yr6lklnkBtVBDTmLnrC -----END CERTIFICATE-----",
  "serial_number": "string",
  "subject_key_identifier": "26:1F:C5:53:5B:D7:9E:E2:37:74:F4:F4:06:09:03:3D:EB:41:75:D8",
  "svm": {
    "name": "svm1",
  "type": "string",
  "uuid": "string"
Status: 201, Created
num_records
integer
Number of records
records
array[security_certificate]
  "records": [
      "ca": "string",
      "name": "cert1",
      "svm": {
        "name": "svm1",
      "type": "string",
      "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
3735645
Cannot specify a value for serial. It is generated automatically.
3735622
The certificate type is not supported.
3735664
The specified key size is not supported in FIPS mode.
3735665
The specified hash function is not supported in FIPS mode.
3735553
Failed to create self-signed Certificate.
3735646
Failed to store the certificates.
3735693
The certificate installation failed as private key was empty.
3735618
Cannot accept private key for server_ca or client_ca.
52363365
Failed to allocate memory.
52559975
Failed to read the certificate due to incorrect formatting.
52363366
Unsupported key type.
52560123
Failed to read the key due to incorrect formatting.
52559972
The certificates start date is later than the current date.
52559976
The certificate and private key do not match.
52559973
The certificate has expired.
52363366
Logic error: use of a dead object.
3735696
Intermediate certificates are not supported with client_ca and server_ca type certificates.
52559974
The certificate is not supported in FIPS mode.
3735676
Cannot continue the installation without a value for the common name. Since the subject field in the certificate is empty, the field "common_name" must have a value to continue with the installation.
3735558
Failed to extract information about Common Name from the certificate.
3735588
The common name (CN) extracted from the certificate is not valid.
3735632
Failed to extract Certificate Authority Information from the certificate.
string
svm
name
string
The name of the SVM.
uuid
string
string
ca
string
common_name
string
expiry_time
string
hash_function
string
array[string]
key_size
integer
name
string
private_key
string
public_certificate
string
serial_number
string
string
svm
svm
type
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
