Create or install security certificates
Creates or installs security certificates on the ONTAP cluster, including downloading certificates from Azure Key Vault. Use this endpoint to establish secure connections and manage certificate lifecycles within your storage environment.
HTTP method and endpoint
POST /security/certificates
Introduced in
ONTAP 9.6
Usage notes
Creates or installs a certificate or downloads a certificate from Azure Key Vault (AKV) and installs it on the ONTAP cluster.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create or install the certificate. -
common_name- Common name of the certificate. Required when creating a certificate. -
type- Type of certificate. -
public_certificate- Public key certificate in PEM format. Required when installing a certificate. -
private_key- Private key certificate in PEM format. Required when installing a CA-signed certificate.
Recommended optional properties
expiry_time- Certificate expiration time. Specifying an expiration time is recommended when creating a certificate. -
key_size- Key size of the certificate in bits. Specifying a strong key size is recommended when creating a certificate. -
name- Unique certificate name per SVM or the name of the certificate in AKV, required for downloading AKV certificates. If one is not provided, it is automatically generated.
AKV required properties for downloading a certificate
azure.key_vault- URI of the Azure Key Vault. -
azure.client_id- Application (client) ID of the deployed Azure application with appropriate access to an AKV. -
azure.tenant_id- Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV. -
azure.client_secret- Secret used by the application to prove its identity to AKV. -
azure.client_certificate- PKCS12 certificate used by the application to prove its identity to AKV.
AKV optional properties for downloading a certificate
azure.oauth_host- Open authorization server host name. -
azure.proxy.type- Type of proxy (http, https etc.) if proxy configuration is used. -
azure.proxy.host- Proxy hostname if proxy configuration is used. -
azure.proxy.port- Proxy port number if proxy configuration is used. -
azure.proxy.username- Proxy username if proxy configuration is used. -
azure.proxy.password- Proxy password if proxy configuration is used. -
azure.timeout- AKV connection timeout in seconds. -
azure.verify_host- Verify the identity of the AKV host name.
Default property values
If not specified in POST, the following default property values are assigned:
key_size- 2048 -
expiry_time- P365DT -
hash_function- sha256
Related ONTAP commands
security certificate create -
security certificate install -
security certificate azure-install
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
authority_key_identifier |
string |
Provides the key identifier of the issuing CA certificate that signed the SSL certificate. |
azure |
ca |
string |
Certificate authority |
common_name |
string |
FQDN or custom common name. Provide on POST when creating a self-signed certificate. |
expiry_time |
string |
Certificate expiration time, in ISO 8601 duration format or date and time format. Can be provided on POST if creating self-signed certificate. The expiration time range is between 1 day to 10 years. |
hash_function |
string |
Hashing function. Can be provided on POST when creating a self-signed certificate. Hash functions md5 and sha1 are not allowed on POST. |
intermediate_certificates |
array[string] |
Chain of intermediate Certificates in PEM format. Only valid in POST when installing a certificate. |
key_size |
integer |
Key size of requested Certificate in bits. One of 512, 1024, 1536, 2048, 3072. Can be provided on POST if creating self-signed certificate with a minimum permissible value of 2048. |
name |
string |
Certificate name or name of the certificate to be downloaded from the Azure Key Vault (AKV). If not provided in POST, a unique name specific to the SVM is automatically generated. |
private_key |
string |
Private key Certificate in PEM format. Only valid for create when installing a CA-signed certificate. This is not audited. |
public_certificate |
string |
Public key Certificate in PEM format. If this is not provided in POST, a self-signed certificate is created. |
serial_number |
string |
Serial number of certificate. |
subject_alternatives |
subject_key_identifier |
string |
Provides the key identifier used to identify the public key in the SSL certificate. |
svm |
type |
string |
Type of Certificate. The following types are supported:
uuid |
string |
Unique ID that identifies a certificate. |
Example request
"authority_key_identifier": "26:1F:C5:53:5B:D7:9E:E2:37:74:F4:F4:06:09:03:3D:EB:41:75:D7",
"azure": {
"client_certificate": "PEM Cert",
"client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
"client_secret": "abcdef",
"key_vault": "https://kmip-akv-keyvault.vault.azure.net/",
"oauth_host": "login.microsoftonline.com",
"proxy": {
"host": "proxy.eng.com",
"password": "proxypassword",
"port": 1234,
"type": "string",
"username": "proxyuser"
"tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
"timeout": 25
"ca": "string",
"common_name": "test.domain.com",
"expiry_time": "2030-01-25 06:20:13 -0500",
"hash_function": "string",
"intermediate_certificates": [
"<CERTIFICATE-CONTENT>"
"key_size": 512,
"name": "string",
"private_key": "-----BEGIN PRIVATE KEY-----\\nprivate-key\\n-----END PRIVATE KEY-----\\n",
"public_certificate": "<CERTIFICATE-CONTENT>",
"serial_number": "string",
"subject_alternatives": {
"dns": [
"*.example.com"
"email": [
"abc@example.com"
"ip": [
"10.225.34.10"
"uri": [
"http://example.com"
"subject_key_identifier": "26:1F:C5:53:5B:D7:9E:E2:37:74:F4:F4:06:09:03:3D:EB:41:75:D8",
"svm": {
"name": "svm1",
"type": "string",
"uuid": "string"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[security_certificate] |
"num_records": 1,
"records": [
"azure": {
"proxy": {
"port": 1234,
"type": "string",
"timeout": 25
"ca": "string",
"key_size": 512,
"name": "string",
"dns": [
"*.example.com"
"email": [
"abc@example.com"
"ip": [
"10.225.34.10"
"uri": [
"svm": {
"name": "svm1",
"type": "string",
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
3735645 |
Cannot specify a value for serial. It is generated automatically. |
3735622 |
The certificate type is not supported. |
3735664 |
The specified key size is not supported in FIPS mode. |
3735665 |
The specified hash function is not supported in FIPS mode. |
3735553 |
Failed to create self-signed Certificate. |
3735646 |
Failed to store the certificates. |
3735693 |
The certificate installation failed as private key was empty. |
3735618 |
Cannot accept private key for server_ca or client_ca. |
52363365 |
Failed to allocate memory. |
52559975 |
Failed to read the certificate due to incorrect formatting. |
52363366 |
Unsupported key type. |
52560123 |
Failed to read the key due to incorrect formatting. |
52559972 |
The certificates start date is later than the current date. |
52559976 |
The certificate and private key do not match. |
52559973 |
The certificate has expired. |
52363366 |
Logic error: use of a dead object. |
3735696 |
Intermediate certificates are not supported with client_ca and server_ca type certificates. |
52559974 |
The certificate is not supported in FIPS mode. |
3735676 |
Cannot continue the installation without a value for the common name. Since the subject field in the certificate is empty, the field "common_name" must have a value to continue with the installation. |
3735558 |
Failed to extract information about Common Name from the certificate. |
3735588 |
The common name (CN) extracted from the certificate is not valid. |
3735632 |
Failed to extract Certificate Authority Information from the certificate. |
3735700 |
The specified key size is not supported. |
52560173 |
The hash function is not supported for digital signatures. |
3735751 |
Failed to authenticate and fetch the access token from Azure OAuth host. |
3735752 |
Failed to extract the private key from the Azure Key Vault certificate. |
3735753 |
Unsupported content_type in the Azure secrets response. |
3735754 |
Internal error. Failed to parse the JSON response from Azure Key Vault. |
3735755 |
REST call to Azure failed. |
3735756 |
Invalid client certificate. |
3735757 |
Internal error. Failed to generate client assertion. |
3735762 |
Provided Azure Key Vault configuration is incorrect. |
3735763 |
Provided Azure Key Vault configuration is incomplete. |
3735764 |
href |
string |
_links
proxy
host |
string |
Proxy host. |
password |
string |
Proxy password. Password is not audited. |
port |
integer |
Proxy port. |
type |
string |
Proxy type. |
username |
string |
Proxy username. |
azure
client_certificate |
string |
PKCS12 certificate used by the application to prove its identity to AKV. |
client_id |
string |
Application client ID of the deployed Azure application with appropriate access to an AKV. |
client_secret |
string |
Secret used by the application to prove its identity to AKV. |
key_vault |
string |
URI of the deployed AKV that is used by ONTAP for storing keys.
oauth_host |
string |
Open authorization server host name. |
proxy |
tenant_id |
string |
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV. |
timeout |
integer |
AKV connection timeout, in seconds. The allowed range is between 0 to 30 seconds. |
verify_host |
boolean |
Verify the identity of the AKV host name. By default, verify_host is set to true. |
dns |
array[string] |
A list of DNS names for Subject Alternate name extension. |
array[string] |
A list of email addresses for Subject Alternate name extension |
ip |
array[string] |
A list of IP addresses for Subject Alternate name extension. |
uri |
array[string] |
A list of URIs for Subject Alternate name extension. |
svm
name |
string |
uuid |
string |
string |
azure |
ca |
string |
common_name |
string |
expiry_time |
string |
hash_function |
string |
array[string] |
key_size |
integer |
name |
string |
private_key |
string |
string |
serial_number |
string |
string |
svm |
type |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
