REST API reference
Create or install security certificates
Creates or installs security certificates on an ONTAP cluster, including downloading from Azure Key Vault as needed. This enables secure communications and authentication within your storage environment.
HTTP method and endpoint
POST /security/certificates
Introduced in
ONTAP 9.6
Usage notes
Creates or installs a certificate or downloads a certificate from Azure Key Vault (AKV) and installs it on the ONTAP cluster.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create or install the certificate.
  • common_name - Common name of the certificate. Required when creating a certificate.
  • type - Type of certificate.
  • public_certificate - Public key certificate in PEM format. Required when installing a certificate.
  • private_key - Private key certificate in PEM format. Required when installing a CA-signed certificate.
  • expiry_time - Certificate expiration time. Specifying an expiration time is recommended when creating a certificate.
  • key_size - Key size of the certificate in bits. Specifying a strong key size is recommended when creating a certificate.
  • name - Unique certificate name per SVM or the name of the certificate in AKV, required for downloading AKV certificates. If one is not provided, it is automatically generated.
AKV required properties for downloading a certificate
  • azure.key_vault - URI of the Azure Key Vault.
  • azure.client_id - Application (client) ID of the deployed Azure application with appropriate access to an AKV.
  • azure.tenant_id - Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV.
  • azure.client_secret - Secret used by the application to prove its identity to AKV.
  • azure.client_certificate - PKCS12 certificate used by the application to prove its identity to AKV.
AKV optional properties for downloading a certificate
  • azure.oauth_host - Open authorization server host name.
  • azure.proxy.type - Type of proxy (http, https etc.) if proxy configuration is used.
  • azure.proxy.host - Proxy hostname if proxy configuration is used.
  • azure.proxy.port - Proxy port number if proxy configuration is used.
  • azure.proxy.username - Proxy username if proxy configuration is used.
  • azure.proxy.password - Proxy password if proxy configuration is used.
  • azure.timeout - AKV connection timeout in seconds.
  • azure.verify_host - Verify the identity of the AKV host name.
Default property values
If not specified in POST, the following default property values are assigned:
  • key_size - 2048
  • expiry_time - P365DT
  • hash_function - sha256
  • security certificate create
  • security certificate install
  • security certificate azure-install
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
authority_key_identifier
string
Provides the key identifier of the issuing CA certificate that signed the SSL certificate.
azure
azure
ca
string
Certificate authority
common_name
string
FQDN or custom common name. Provide on POST when creating a self-signed certificate.
expiry_time
string
Certificate expiration time, in ISO 8601 duration format or date and time format. Can be provided on POST if creating self-signed certificate. The expiration time range is between 1 day to 10 years.
hash_function
string
Hashing function. Can be provided on POST when creating a self-signed certificate. Hash functions md5 and sha1 are not allowed on POST.
intermediate_certificates
array[string]
Chain of intermediate Certificates in PEM format. Only valid in POST when installing a certificate.
key_size
integer
Key size of requested Certificate in bits. One of 512, 1024, 1536, 2048, 3072. Can be provided on POST if creating self-signed certificate with a minimum permissible value of 2048.
name
string
Certificate name or name of the certificate to be downloaded from the Azure Key Vault (AKV). If not provided in POST, a unique name specific to the SVM is automatically generated.
private_key
string
Private key Certificate in PEM format. Only valid for create when installing a CA-signed certificate. This is not audited.
public_certificate
string
Public key Certificate in PEM format. If this is not provided in POST, a self-signed certificate is created.
serial_number
string
Serial number of certificate.
subject_alternatives
subject_key_identifier
string
Provides the key identifier used to identify the public key in the SSL certificate.
svm
svm
type
string
Type of Certificate. The following types are supported:
  • client - a certificate and its private key used by an SSL client in ONTAP.
  • server - a certificate and its private key used by an SSL server in ONTAP.
  • client_ca - a Certificate Authority certificate used by an SSL server in ONTAP to verify an SSL client certificate.
  • server_ca - a Certificate Authority certificate used by an SSL client in ONTAP to verify an SSL server certificate.
  • root_ca - a self-signed certificate used by ONTAP to sign other certificates by acting as a Certificate Authority.
  • enum: ["client", "server", "client_ca", "server_ca", "root_ca"]
  • Introduced in: 9.6
  • x-nullable: true
uuid
string
Unique ID that identifies a certificate.
Example request
  "authority_key_identifier": "26:1F:C5:53:5B:D7:9E:E2:37:74:F4:F4:06:09:03:3D:EB:41:75:D7",
  "azure": {
    "client_certificate": "PEM Cert",
    "client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
    "client_secret": "abcdef",
    "key_vault": "https://kmip-akv-keyvault.vault.azure.net/",
    "oauth_host": "login.microsoftonline.com",
    "proxy": {
      "host": "proxy.eng.com",
      "password": "proxypassword",
      "port": 1234,
      "type": "string",
      "username": "proxyuser"
    "tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
    "timeout": 25
  "ca": "string",
  "common_name": "test.domain.com",
  "expiry_time": "2030-01-25 06:20:13 -0500",
  "hash_function": "string",
  "intermediate_certificates": [
    "<CERTIFICATE-CONTENT>"
  "key_size": 512,
  "name": "string",
  "private_key": "-----BEGIN PRIVATE KEY-----\\nprivate-key\\n-----END PRIVATE KEY-----\\n",
  "public_certificate": "<CERTIFICATE-CONTENT>",
  "serial_number": "string",
  "subject_alternatives": {
    "dns": [
      "*.example.com"
    "email": [
      "abc@example.com"
    "ip": [
      "10.225.34.10"
    "uri": [
      "http://example.com"
  "subject_key_identifier": "26:1F:C5:53:5B:D7:9E:E2:37:74:F4:F4:06:09:03:3D:EB:41:75:D8",
  "svm": {
    "name": "svm1",
  "type": "string",
  "uuid": "string"
Status: 201, Created
num_records
integer
Number of records
records
array[security_certificate]
  "num_records": 1,
  "records": [
      "azure": {
        "proxy": {
          "port": 1234,
          "type": "string",
        "timeout": 25
      "ca": "string",
      "key_size": 512,
      "name": "string",
        "dns": [
          "*.example.com"
        "email": [
          "abc@example.com"
        "ip": [
          "10.225.34.10"
        "uri": [
      "svm": {
        "name": "svm1",
      "type": "string",
      "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
3735645
Cannot specify a value for serial. It is generated automatically.
3735622
The certificate type is not supported.
3735664
The specified key size is not supported in FIPS mode.
3735665
The specified hash function is not supported in FIPS mode.
3735553
Failed to create self-signed Certificate.
3735646
Failed to store the certificates.
3735693
The certificate installation failed as private key was empty.
3735618
Cannot accept private key for server_ca or client_ca.
52363365
Failed to allocate memory.
52559975
Failed to read the certificate due to incorrect formatting.
52363366
Unsupported key type.
52560123
Failed to read the key due to incorrect formatting.
52559972
The certificates start date is later than the current date.
52559976
The certificate and private key do not match.
52559973
The certificate has expired.
52363366
Logic error: use of a dead object.
3735696
Intermediate certificates are not supported with client_ca and server_ca type certificates.
52559974
The certificate is not supported in FIPS mode.
3735676
Cannot continue the installation without a value for the common name. Since the subject field in the certificate is empty, the field "common_name" must have a value to continue with the installation.
3735558
Failed to extract information about Common Name from the certificate.
3735588
The common name (CN) extracted from the certificate is not valid.
3735632
Failed to extract Certificate Authority Information from the certificate.
3735700
The specified key size is not supported.
52560173
The hash function is not supported for digital signatures.
3735751
Failed to authenticate and fetch the access token from Azure OAuth host.
3735752
Failed to extract the private key from the Azure Key Vault certificate.
3735753
Unsupported content_type in the Azure secrets response.
3735754
Internal error. Failed to parse the JSON response from Azure Key Vault.
3735755
REST call to Azure failed.
3735756
Invalid client certificate.
3735757
Internal error. Failed to generate client assertion.
3735762
Provided Azure Key Vault configuration is incorrect.
3735763
Provided Azure Key Vault configuration is incomplete.
3735764
string
proxy
host
string
Proxy host.
password
string
Proxy password. Password is not audited.
port
integer
Proxy port.
type
string
Proxy type.
username
string
Proxy username.
azure
client_certificate
string
client_id
string
Application client ID of the deployed Azure application with appropriate access to an AKV.
client_secret
string
key_vault
string
URI of the deployed AKV that is used by ONTAP for storing keys.
oauth_host
string
proxy
proxy
tenant_id
string
timeout
integer
AKV connection timeout, in seconds. The allowed range is between 0 to 30 seconds.
verify_host
boolean
Verify the identity of the AKV host name. By default, verify_host is set to true.
dns
array[string]
A list of DNS names for Subject Alternate name extension.
email
array[string]
A list of email addresses for Subject Alternate name extension
ip
array[string]
A list of IP addresses for Subject Alternate name extension.
uri
array[string]
A list of URIs for Subject Alternate name extension.
svm
name
string
uuid
string
string
azure
azure
ca
string
common_name
string
expiry_time
string
hash_function
string
array[string]
key_size
integer
name
string
private_key
string
public_certificate
string
serial_number
string
string
svm
svm
type
string
  • x-nullable: true
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
