Add a CA certificate to IPsec
Adds a CA certificate to IPsec, enhancing secure communications. Use this when you need to integrate an existing CA certificate with IPsec for your cluster.
HTTP method and endpoint
POST /security/ipsec/ca-certificates
Introduced in
ONTAP 9.10
Usage notes
Add CA certificate to IPsec. The CA certificate should already be installed on the cluster prior to adding them to IPsec. The CA certificate can be installed on the cluster using the /security/certificates endpoint. The svm.uuid or svm.name should not be supplied for certificates that have a scope of cluster.
Related ONTAP commands
security ipsec ca-certificate add
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
certificate |
IPsec CA certificate UUID |
svm |
Example request
"certificate": {
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[ipsec_ca_certificate] |
"records": [
"certificate": {
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66257296 |
CA certificate is not installed. |
href |
string |
_links
certificate
uuid |
string |
Certificate UUID |
svm
name |
string |
The name of the SVM. |
uuid |
string |
certificate |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
