REST API reference
Add a CA certificate to IPsec
Adds a CA certificate to IPsec to establish secure communication by verifying identities through trusted certificate authorities. This is typically done when you need to authenticate and encrypt data between IPsec peers.
HTTP method and endpoint
POST /security/ipsec/ca-certificates
Introduced in
ONTAP 9.10
Usage notes
Add CA certificate to IPsec. The CA certificate should already be installed on the cluster prior to adding them to IPsec. The CA certificate can be installed on the cluster using the /security/certificates endpoint. The svm.uuid or svm.name should not be supplied for certificates that have a scope of cluster.
  • security ipsec ca-certificate add
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
certificate
certificate
IPsec CA certificate UUID
svm
svm
Example request
  "certificate": {
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[ipsec_ca_certificate]
  "num_records": 1,
  "records": [
      "certificate": {
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
66257296
CA certificate is not installed.
string
certificate
uuid
string
Certificate UUID
svm
name
string
The name of the SVM.
uuid
string
certificate
certificate
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
