Add a CA certificate to IPsec
POST /security/ipsec/ca-certificates
Introduced In: 9.10
Add CA certificate to IPsec. The CA certificate should already be installed on the cluster prior to adding them to IPsec. The CA certificate can be installed on the cluster using the /security/certificates endpoint. The svm.uuid or svm.name should not be supplied for certificates that have a scope of cluster.
Related ONTAP commands
security ipsec ca-certificate add
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
certificate |
IPsec CA certificate UUID |
svm |
Example request
"certificate": {
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[ipsec_ca_certificate] |
"num_records": 1,
"records": [
"certificate": {
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66257304 |
CA certificate is not installed. |
href |
string |
_links
certificate
uuid |
string |
Certificate UUID |
svm
name |
string |
uuid |
string |
certificate |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
