Create or remove litigations for a path
Manages litigations for a specified path, supporting legal compliance efforts by starting or ending legal holds on data. Use this to ensure data is retained or released according to legal requirements.
HTTP method and endpoint
POST /storage/snaplock/litigations/{litigation.id}/operations
Introduced in
ONTAP 9.7
Usage notes
Creates or removes litigations for the specified path.
Required properties
type- Legal-Hold operation type. -
path- Litigation path.
Related ONTAP commands
snaplock legal-hold begin -
snaplock legal-hold end
litigation.id |
string |
path |
True |
Litigation ID |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
id |
integer |
Operation ID. |
num_files_failed |
string |
Specifies the number of files on which legal-hold operation failed. |
num_files_processed |
string |
Specifies the number of files on which legal-hold operation was successful. |
num_files_skipped |
string |
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation. |
num_inodes_ignored |
string |
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files. |
path |
string |
Specifies the path on which legal-hold operation is applied. |
state |
string |
Specifies the status of legal-hold operation. |
Example request
"id": 16842759,
"num_files_failed": "0",
"num_files_processed": "30",
"num_files_skipped": "10",
"num_inodes_ignored": "10",
"path": "/dir1",
"state": "completed"
Status: 201, Created
id |
integer |
Operation ID. |
num_files_failed |
string |
string |
num_files_skipped |
string |
string |
path |
string |
state |
string |
"id": 16842759,
"path": "/dir1",
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
14090343 |
Invalid Field |
href |
string |
_links
snaplock_legal_hold_operation
id |
integer |
Operation ID. |
num_files_failed |
string |
string |
num_files_skipped |
string |
string |
path |
string |
state |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
