Create or remove litigations for a path
Manages litigations for a specified path by creating or removing them. Use this when you need to initiate or conclude a legal hold operation on a storage path.
HTTP method and endpoint
POST /storage/snaplock/litigations/{litigation.id}/operations
Introduced in
ONTAP 9.7
Usage notes
Creates or removes litigations for the specified path.
Required properties
type- Legal-Hold operation type. -
path- Litigation path.
Related ONTAP commands
snaplock legal-hold begin -
snaplock legal-hold end
litigation.id |
string |
path |
True |
Litigation ID |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
id |
integer |
Operation ID. |
num_files_failed |
string |
Specifies the number of files on which legal-hold operation failed. |
num_files_processed |
string |
Specifies the number of files on which legal-hold operation was successful. |
num_files_skipped |
string |
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation. |
num_inodes_ignored |
string |
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files. |
path |
string |
Specifies the path on which legal-hold operation is applied. |
state |
string |
Specifies the status of legal-hold operation. |
Example request
"id": 16842759,
"num_files_failed": 0,
"num_files_processed": 30,
"num_files_skipped": 10,
"num_inodes_ignored": 10,
"path": "/dir1",
"state": "completed"
Status: 201, Created
id |
integer |
Operation ID. |
num_files_failed |
string |
string |
num_files_skipped |
string |
string |
path |
string |
state |
string |
"id": 16842759,
"path": "/dir1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
14090343 |
Invalid Field |
href |
string |
_links
snaplock_legal_hold_operation
id |
integer |
Operation ID. |
num_files_failed |
string |
string |
num_files_skipped |
string |
string |
path |
string |
state |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
