REST API reference
Create or remove litigations for a path
Manages litigation holds for a specified path, determining whether to initiate or end legal retention on stored data. Use this to enforce or release data preservation requirements in compliance scenarios.
HTTP method and endpoint
POST /storage/snaplock/litigations/{litigation.id}/operations
Introduced in
ONTAP 9.7
Usage notes
Creates or removes litigations for the specified path.
Required properties
  • type - Legal-Hold operation type.
  • path - Litigation path.
  • snaplock legal-hold begin
  • snaplock legal-hold end
litigation.id
string
path
True
Litigation ID
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
id
integer
Operation ID.
num_files_failed
string
Specifies the number of files on which legal-hold operation failed.
num_files_processed
string
Specifies the number of files on which legal-hold operation was successful.
num_files_skipped
string
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation.
num_inodes_ignored
string
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files.
path
string
Specifies the path on which legal-hold operation is applied.
state
string
Specifies the status of legal-hold operation.
Example request
  "id": 16842759,
  "num_files_failed": "0",
  "num_files_processed": "30",
  "num_files_skipped": "10",
  "num_inodes_ignored": "10",
  "path": "/dir1",
  "state": "completed"
Status: 201, Created
id
integer
Operation ID.
num_files_failed
string
num_files_processed
string
num_files_skipped
string
num_inodes_ignored
string
path
string
state
string
  "id": 16842759,
  "path": "/dir1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response codes
Error code Description
14090346
Internal Error. Wait a few minutes, then try the command again
14090343
Invalid Field
string
id
integer
Operation ID.
num_files_failed
string
num_files_processed
string
num_files_skipped
string
num_inodes_ignored
string
path
string
state
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
