Create a volume Snapshot copy
Creates a volume Snapshot copy to capture the current state of a volume at a specific point in time. This is typically used for data protection and disaster recovery purposes.
HTTP method and endpoint
POST /storage/volumes/{volume.uuid}/snapshots
Introduced in
ONTAP 9.6
Required properties
name- Name of the Snapshot copy to be created.
Recommended optional properties
comment- Comment associated with the Snapshot copy. -
expiry_time- Snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached. -
snapmirror_label- Label for SnapMirror operations.
Related ONTAP commands
snapshot create
Learn more
volume.uuid |
string |
path |
True |
Volume UUID |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
A comment associated with the Snapshot copy. This is an optional attribute for POST or PATCH. |
create_time |
string |
Creation time of the Snapshot copy. It is the volume access time when the Snapshot copy was created. |
expiry_time |
string |
The expiry time for the Snapshot copy. This is an optional attribute for POST or PATCH. Snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached. |
name |
string |
Snapshot copy. Valid in POST or PATCH. |
owners |
array[string] |
provenance_volume |
reclaimable_space |
integer |
Space reclaimed when the Snapshot copy is deleted, in bytes. |
size |
integer |
Size of the active file system at the time the Snapshot copy is captured. The actual size of the Snapshot copy also includes those blocks trapped by other Snapshot copies. On a Snapshot copy deletion, the "size" amount of blocks is the maximum number of blocks available. On a Snapshot copy restore, the "afs-used size" value will match the Snapshot copy "size" value. |
snaplock_expiry_time |
string |
SnapLock expiry time for the Snapshot copy, if the Snapshot copy is taken on a SnapLock volume. A Snapshot copy is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. |
snapmirror_label |
string |
Label for SnapMirror operations |
state |
string |
State of the Snapshot copy. There are cases where some Snapshot copies are not complete. In the "partial" state, the Snapshot copy is consistent but exists only on the subset of the constituents that existed prior to the FlexGroup's expansion. Partial Snapshot copies cannot be used for a Snapshot copy restore operation. A Snapshot copy is in an "invalid" state when it is present in some FlexGroup constituents but not in others. At all other times, a Snapshot copy is valid. |
svm |
uuid |
string |
The UUID of the Snapshot copy in the volume that uniquely identifies the Snapshot copy in that volume. |
version_uuid |
string |
The 128 bit identifier that uniquely identifies a snapshot and its logical data layout. |
volume |
Example request
"comment": "string",
"create_time": "2019-02-04T19:00:00Z",
"expiry_time": "2019-02-04T19:00:00Z",
"name": "this_snapshot",
"owners": [
"string"
"provenance_volume": {
"uuid": "4cd8a442-86d1-11e0-ae1c-125648563413"
"size": 122880,
"snaplock_expiry_time": "2019-02-04T19:00:00Z",
"snapmirror_label": "string",
"state": "string",
"svm": {
"name": "svm1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"version_uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"volume": {
"name": "volume1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Code
| Error Code | Description |
524479 |
The specified volume is not online or does not have enough space to create a Snapshot copy. |
2621462 |
The specified SVM name does not exist. |
1638433 |
A Snapshot copy with the specified name already exists. |
1638461 |
Snapshot copies can only be created on read/write (RW) volumes. |
1638477 |
User-created Snapshot copy names cannot begin with the specified prefix. |
1638518 |
The specified Snapshot copy name is invalid. |
1638532 |
Failed to create the Snapshot copy on the specified volume because a revert operation is in progress. |
1638537 |
Cannot determine the status of the Snapshot copy create operation for the specified volume. |
1638616 |
Bulk Snapshot copy create is not supported with multiple Snapshot copy names. |
1638617 |
Bulk Snapshot copy create is not supported with volume names in a mixed-version cluster. |
1638618 |
The property cannot be specified for Snapshot copy create. |
href |
string |
_links
provenance_volume
uuid |
string |
UUID for the volume that is used to identify the source volume in a mirroring relationship. When the mirroring relationship is broken, a volume's Instance UUID and Provenance UUID are made identical. An unmirrored volume's Provenance UUID is the same as its Instance UUID. This field is valid for flexible volumes only. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
volume
name |
string |
The name of the volume. |
uuid |
string |
snapshot
The Snapshot copy object represents a point in time Snapshot copy of a volume.
comment |
string |
create_time |
string |
expiry_time |
string |
name |
string |
owners |
array[string] |
provenance_volume |
reclaimable_space |
integer |
size |
integer |
string |
snapmirror_label |
string |
state |
string |
svm |
uuid |
string |
version_uuid |
string |
volume |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
