REST API reference
Create a volume Snapshot copy
Creates a volume Snapshot copy to capture the state of a volume at a specific point in time. This is useful for data protection and recovery scenarios, letting you preserve and restore data as needed.
HTTP method and endpoint
POST /storage/volumes/{volume.uuid}/snapshots
Introduced in
ONTAP 9.6
Required properties
  • name - Name of the Snapshot copy to be created.
  • comment - Comment associated with the Snapshot copy.
  • expiry_time - Snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached.
  • snapmirror_label - Label for SnapMirror operations.
  • snaplock_expiry_time - Expiry time for Snapshot copy locking enabled volumes.
  • snapshot create
volume.uuid
string
path
True
Volume UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
A comment associated with the Snapshot copy. This is an optional attribute for POST or PATCH.
create_time
string
Creation time of the Snapshot copy. It is the volume access time when the Snapshot copy was created.
delta
snapshot_delta
Reports the amount of space consumed between two WAFL file systems, in bytes. The two WAFL file systems should be specified in a comma-separated format using the "name" parameter. To determine the space consumed between a Snapshot copy and the Active File System, only the Snapshot copy name needs to be mentioned.
expiry_time
string
The expiry time for the Snapshot copy. This is an optional attribute for POST or PATCH. Snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached.
logical_size
integer
Size of the logical used file system at the time the Snapshot copy is captured.
name
string
Snapshot copy. Valid in POST or PATCH.
owners
array[string]
provenance_volume
provenance_volume
reclaimable_space
integer
Space reclaimed when the Snapshot copy is deleted, in bytes.
size
integer
Size of the active file system at the time the Snapshot copy is captured. The actual size of the Snapshot copy also includes those blocks trapped by other Snapshot copies. On a Snapshot copy deletion, the "size" amount of blocks is the maximum number of blocks available. On a Snapshot copy restore, the "afs-used size" value will match the Snapshot copy "size" value.
string
SnapLock expiry time for the Snapshot copy, if the Snapshot copy is taken on a SnapLock volume. A Snapshot copy is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. This option can be set during Snapshot copy POST and Snapshot copy PATCH on Snapshot copy locking enabled volumes.
snapmirror_label
string
state
string
State of the FlexGroup volume Snapshot copy. In the "pre_conversion" state, the Snapshot copy was created before converting the FlexVol to a FlexGroup volume. A recently created Snapshot copy can be in the "unknown" state while the system is calculating the state. In the "partial" state, the Snapshot copy is consistent but exists only on the subset of the constituents that existed prior to the FlexGroup's expansion. Partial Snapshot copies cannot be used for a Snapshot copy restore operation. A Snapshot copy is in an "invalid" state when it is present in some FlexGroup constituents but not in others. At all other times, a Snapshot copy is valid.
svm
svm
uuid
string
The UUID of the Snapshot copy in the volume that uniquely identifies the Snapshot copy in that volume.
version_uuid
string
The 128 bit identifier that uniquely identifies a snapshot and its logical data layout.
volume
volume
Example request
  "comment": "string",
  "create_time": "2019-02-04 14:00:00 -0500",
  "delta": {
    "size_consumed": 0,
    "time_elapsed": "string"
  "expiry_time": "2019-02-04 14:00:00 -0500",
  "logical_size": 1228800,
  "name": "this_snapshot",
  "owners": [
    "string"
  "provenance_volume": {
    "uuid": "4cd8a442-86d1-11e0-ae1c-125648563413"
  "size": "122880",
  "snaplock_expiry_time": "2019-02-04 14:00:00 -0500",
  "snapmirror_label": "string",
  "state": "string",
  "svm": {
    "name": "svm1",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "version_uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "volume": {
    "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Code
Error Code Description
524479
The specified volume is not online or does not have enough space to create a Snapshot copy.
2621462
The specified SVM name does not exist.
525059
A Snapshot copy with the specified name already exists.
1638461
Snapshot copies can only be created on read/write (RW) volumes.
1638477
User-created Snapshot copy names cannot begin with the specified prefix.
1638518
The specified Snapshot copy name is invalid.
1638532
Failed to create the Snapshot copy on the specified volume because a revert operation is in progress.
1638537
Cannot determine the status of the Snapshot copy create operation for the specified volume.
1638616
Bulk Snapshot copy create is not supported with multiple Snapshot copy names.
1638617
Bulk Snapshot copy create is not supported with volume names in a mixed-version cluster.
1638618
The property cannot be specified for Snapshot copy create.
1638630
Snapshot copy create operation is not supported on destination of SnapMirror Business Continuity (SMBC) relationship with policy-type "automated-failover-duplex".
string
snapshot_delta
size_consumed
integer
Indicates the space that has changed between two specified WAFL file systems, in bytes.
time_elapsed
string
Time elapsed between two specified WAFL file systems.
provenance_volume
uuid
string
UUID for the volume that is used to identify the source volume in a mirroring relationship. When the mirroring relationship is broken, a volume's Instance UUID and Provenance UUID are made identical. An unmirrored volume's Provenance UUID is the same as its Instance UUID. This field is valid for flexible volumes only.
svm
name
string
uuid
string
volume
name
string
The name of the volume. This field cannot be specified in a POST or PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
snapshot
The Snapshot copy object represents a point in time Snapshot copy of a volume.
comment
string
create_time
string
delta
snapshot_delta
expiry_time
string
logical_size
integer
name
string
owners
array[string]
provenance_volume
provenance_volume
reclaimable_space
integer
size
integer
string
snapmirror_label
string
state
string
svm
svm
uuid
string
version_uuid
string
volume
volume
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
