REST API reference
Creates a volume snapshot copy
  • comment - comment associated with the snapshot copy
  • expiry_time - snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached # related ontap commands
  • snapshot create # learn more
  • [doc /storage/volumes/{volumeuuid}/snapshots](#docs-storage-storage_volumes_{volumeuuid}_snapshots)
POST /storage/volumes/{volume.uuid}/snapshots
Creates a volume Snapshot copy.
Required properties
  • name - Name of the Snapshot copy to be created.
  • comment - Comment associated with the Snapshot copy.
  • expiry_time - Snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached.
  • snapshot create
volume.uuid
string
path
True
Volume UUID
Request Body
Name Type Description
_links
_links
comment
string
A comment associated with the Snapshot copy. This is an optional attribute for POST or PATCH.
create_time
string
Creation time of the Snapshot copy. It is the volume access time when the Snapshot copy was created.
expiry_time
string
The expiry time for the Snapshot copy. This is an optional attribute for POST or PATCH. Snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached.
name
string
Snapshot copy. Valid in POST or PATCH.
snaplock_expiry_time
string
SnapLock expiry time for the Snapshot copy, if the Snapshot copy is taken on a SnapLock volume. A Snapshot copy is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time.
state
string
State of the Snapshot copy. There are cases where some Snapshot copies are not complete. In the "partial" state, the Snapshot copy is consistent but exists only on the subset of the constituents that existed prior to the FlexGroup's expansion. Partial Snapshot copies cannot be used for a Snapshot copy restore operation. A Snapshot copy is in an "invalid" state when it is present in some FlexGroup constituents but not in others. At all other times, a Snapshot copy is valid.
svm
svm
uuid
string
The UUID of the Snapshot copy in the volume that uniquely identifies the Snapshot copy in that volume.
volume
volume
Example request
      "href": "/api/resourcelink"
  "comment": "string",
  "create_time": "2019-02-04 19:00:00 UTC",
  "expiry_time": "2019-02-04 19:00:00 UTC",
  "name": "this_snapshot",
  "snaplock_expiry_time": "2019-02-04 19:00:00 UTC",
  "state": "string",
  "svm": {
    "name": "svm1",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "volume": {
    "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
snapshot
The Snapshot copy object represents a point in time Snapshot copy of a volume.
_links
_links
comment
string
create_time
string
expiry_time
string
name
string
string
state
string
svm
svm
uuid
string
volume
volume
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
