REST API reference
Create a volume snapshot
Creates a volume snapshot to capture the current state of your data, which can be useful for backup or recovery purposes.
HTTP method and endpoint
POST /storage/volumes/{volume.uuid}/snapshots
Introduced in
ONTAP 9.6
Required properties
  • name - Name of the snapshot to be created.
  • comment - Comment associated with the snapshot.
  • expiry_time - snapshots with an expiry time set are not allowed to be deleted until the retention time is reached.
  • snapmirror_label - Label for SnapMirror operations.
  • snaplock_expiry_time - Expiry time for snapshot locking enabled volumes.
  • snapshot create
volume.uuid
string
path
True
Volume UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
A comment associated with the snapshot. This is an optional attribute for POST or PATCH.
compress_savings
integer
Savings due to compression at the time the snapshot was taken in bytes.
create_time
string
Creation time of the snapshot. It is the volume access time when the snapshot was created.
dedup_savings
integer
Savings due to dedup at the time the snapshot was taken in bytes.
delta
snapshot_delta
Reports the amount of space consumed between two WAFL file systems, in bytes. The two WAFL file systems should be specified in a comma-separated format using the "name" parameter. To determine the space consumed between a snapshot and the Active File System, only the snapshot name needs to be mentioned.
expiry_time
string
The expiry time for the snapshot. This is an optional attribute for POST or PATCH. Snapshots with an expiry time set are not allowed to be deleted until the retention time is reached.
logical_size
integer
Size of the logical used file system at the time the snapshot is captured.
name
string
Snapshot. Valid in POST or PATCH.
owners
array[string]
provenance_volume
provenance_volume
reclaimable_space
integer
Space reclaimed when the snapshot is deleted, in bytes.
size
integer
Size of the active file system at the time the snapshot is captured. The actual size of the snapshot also includes those blocks trapped by other snapshots. On a snapshot deletion, the "size" amount of blocks is the maximum number of blocks available. On a snapshot restore, the "afs-used size" value will match the snapshot "size" value.
snaplock
snaplock
string
SnapLock expiry time for the snapshot, if the snapshot is taken on a SnapLock volume. A snapshot is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. This option can be set during snapshot POST and snapshot PATCH on snapshot locking enabled volumes. This field will no longer be supported in a future release. Use snaplock.expiry_time instead.
snapmirror_label
string
state
string
State of the FlexGroup volume snapshot. In the "pre_conversion" state, the snapshot was created before converting the FlexVol to a FlexGroup volume. A recently created snapshot can be in the "unknown" state while the system is calculating the state. In the "partial" state, the snapshot is consistent but exists only on the subset of the constituents that existed prior to the FlexGroup's expansion. Partial snapshots cannot be used for a snapshot restore operation. A snapshot is in an "invalid" state when it is present in some FlexGroup constituents but not in others. At all other times, a snapshot is valid.
svm
svm
uuid
string
The UUID of the snapshot in the volume that uniquely identifies the snapshot in that volume.
vbn0_savings
integer
Savings due vbn0 at the time the snapshot was taken in bytes.
version_uuid
string
The 128 bit identifier that uniquely identifies a snapshot and its logical data layout.
volume
volume
Example request
  "comment": "string",
  "compress_savings": 1131223,
  "create_time": "2019-02-04 14:00:00 -0500",
  "dedup_savings": 1131223,
  "delta": {
    "size_consumed": 0,
    "time_elapsed": "string"
  "expiry_time": "2019-02-04 14:00:00 -0500",
  "logical_size": 1228800,
  "name": "this_snapshot",
  "owners": [
    "string"
  "provenance_volume": {
    "uuid": "4cd8a442-86d1-11e0-ae1c-125648563413"
  "size": "122880",
  "snaplock": {
    "expired": 1,
    "time_until_expiry": "PT3H27M45S"
  "snaplock_expiry_time": "2019-02-04 14:00:00 -0500",
  "snapmirror_label": "string",
  "state": "string",
  "svm": {
    "name": "svm1",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "vbn0_savings": 1131223,
  "version_uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "volume": {
    "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Code
Error Code Description
524479
The specified volume is not online or does not have enough space to create a snapshot.
1520351
Snapshot operation is not allowed.
525062
Cannot exceed maximum number of snapshots.
2621462
The specified SVM name does not exist.
525059
A snapshot with the specified name already exists.
1638461
Snapshots can only be created on read/write (RW) volumes.
1638477
User-created snapshot names cannot begin with the specified prefix.
1638518
The specified snapshot name is invalid.
1638532
Failed to create the snapshot on the specified volume because a revert operation is in progress.
1638537
Cannot determine the status of the snapshot create operation for the specified volume.
1638574
The "expiry-time" parameter is not supported for FlexGroup volumes.
1638616
Bulk snapshot create is not supported with multiple snapshot names.
1638617
Bulk snapshot create is not supported with volume names in a mixed-version cluster.
1638618
The property cannot be specified for snapshot create.
1638630
Snapshot create operation is not supported on destination of SnapMirror active sync relationship with policy-type "automated-failover-duplex".
1638644
POST, DELETE, and PATCH requests on the snapshot session endpoint are not supported on this platform.
string
snapshot_delta
size_consumed
integer
Indicates the space that has changed between two specified WAFL file systems, in bytes.
time_elapsed
string
Time elapsed between two specified WAFL file systems.
provenance_volume
uuid
string
UUID for the volume that is used to identify the source volume in a mirroring relationship. When the mirroring relationship is broken, a volume's Instance UUID and Provenance UUID are made identical. An unmirrored volume's Provenance UUID is the same as its Instance UUID. This field is valid for flexible volumes only.
snaplock
expired
boolean
Indicates whether a SnapLock snapshot has expired.
expiry_time
string
SnapLock expiry time for the snapshot, if the snapshot is taken on a SnapLock volume. A snapshot is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. This option can be set during snapshot POST and snapshot PATCH on snapshot locking enabled volumes. It can also be used to extend the expiry time of a locked snapshot on a SnapLock for SnapVault destination consistency-group.
time_until_expiry
string
Indicates the remaining SnapLock expiry time of a locked snapshot, in seconds. This field is set only when the remaining time interval is less than 136 years.
svm
name
string
uuid
string
volume
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
snapshot
The snapshot object represents a point in time snapshot of a volume.
comment
string
compress_savings
integer
create_time
string
dedup_savings
integer
delta
snapshot_delta
expiry_time
string
logical_size
integer
name
string
owners
array[string]
provenance_volume
provenance_volume
reclaimable_space
integer
size
integer
snaplock
snaplock
string
snapmirror_label
string
state
string
svm
svm
uuid
string
vbn0_savings
integer
version_uuid
string
volume
volume
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
