      Storage bridges endpoint overview
Retrieving storage bridge information
The storage bridge GET API retrieves all of the bridges in the cluster.
1) Retrieves a list of bridges from the cluster
The following example shows the response with a list of bridges from the cluster:
# The API:
/api/storage/bridges
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/bridges" -H "accept: application/hal+json"
# The response:
"records": [
    "wwn": "2000001086a18100",
    "name": "ATTO_2000001086a18100",
        "href": "/api/storage/bridges/2000001086a18100"
    "wwn": "2000001086a18380",
    "name": "ATTO_2000001086a18380",
        "href": "/api/storage/bridges/2000001086a18380"
"num_records": 2,
    "href": "/api/storage/bridges/"
2) Retrieves a specific bridge from the cluster
The following example shows the response of the requested bridge. If there is no bridge with the requested wwn, an error is returned.
# The API:
/api/storage/bridges/{wwn}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/bridges/2000001086a18100" -H "accept: application/hal+json"
# The response:
 "chassis_throughput_state": "ok",
 "dram_single_bit_error_count": 0,
 "firmware_version": "3.10 007A",
 "ip_address": "10.226.57.178",
 "security_enabled": false,
 "monitoring_enabled": true,
 "model": "FibreBridge 7500N",
 "state": "ok",
 "managed_by": "in_band",
 "serial_number": "FB7500N102450",
 "symbolic_name": "RTP-FCSAS02-41KK10",
 "vendor": "atto",
 "last_reboot": {
 "reason": {
   "message": "Reason: \"FirmwareRestart Command\".",
   "code": "39321683"
 "time": "2020-12-09T00:47:58-05:00"
 "paths": [
   "name": "0e",
   "node": {
     "name": "sti8080mcc-htp-005",
     "uuid": "ecc3d992-3a86-11eb-9fab-00a0985a6024",
         "href": "/api/cluster/nodes/ecc3d992-3a86-11eb-9fab-00a0985a6024"
       "href": "/api/storage/ports/ecc3d992-3a86-11eb-9fab-00a0985a6024/0e"
   "target_port": {
     "wwn": "2100001086a18380"
 "temperature_sensor": {
 "name": "Chassis Temperature Sensor",
 "minimum": 0,
 "maximum": 90,
 "reading": 54,
 "state": "ok"
 "fc_ports": [
 "id": 1,
 "state": "online",
 "enabled": true,
 "negotiated_data_rate": 8,
 "configured_data_rate": 8,
 "conn_mode": "ptp",
 "data_rate_capability": 16,
 "wwn": "2100001086a18100",
 "peer_wwn": "0000000000000000",
 "sfp": {
  "vendor": "FINISAR CORP.",
  "serial_number": "UW106SA",
  "part_number": "FTLF8529P3BCV",
 "id": 2,
 "state": "online",
 "enabled": true,
 "negotiated_data_rate": 16,
 "configured_data_rate": 16,
 "conn_mode": "ptp",
 "wwn": "2200001086a18100",
 "sfp": {
  "serial_number": "UW1072B",
 "power_supply_units": [
 "name": "A",
 "state": "ok"
 "name": "B",
 "state": "ok"
 "sas_ports": [
 "id": 1,
  "state": "online",
  "enabled": true,
  "data_rate_capability": 12,
  "negotiated_data_rate": 6,
  "wwn": "5001086000a18100",
  "phy_1": {
    "state": "online"
  "phy_2": {
    "state": "online"
  "phy_3": {
    "state": "online"
  "phy_4": {
    "state": "online"
  "cable": {
    "vendor": "Molex Inc.",
    "serial_number": "618130935",
    "technology": "Passive Copper 5m ID:00",
    "part_number": "112-00431"
  "state": "offline",
  "enabled": false,
  "negotiated_data_rate": 0,
  "wwn": "5001086000a18104",
  "phy_1": {
    "state": "offline"
  "phy_2": {
    "state": "offline"
  "phy_3": {
    "state": "offline"
  "phy_4": {
    "state": "offline"
  "state": "offline",
  "enabled": false,
  "wwn": "5001086000a18108",
  "phy_1": {
    "state": "offline"
  "phy_2": {
    "state": "offline"
  "phy_3": {
    "state": "offline"
  "phy_4": {
    "state": "offline"
  "state": "offline",
  "enabled": false,
  "wwn": "5001086000a1810c",
  "phy_1": {
    "state": "offline"
  "phy_2": {
    "state": "offline"
  "phy_3": {
    "state": "offline"
  "phy_4": {
    "state": "offline"
