ONTAP REST API Storage bridges endpoints
Retrieving storage bridge information
The storage bridge GET API retrieves all of the bridges in the cluster.
1) Retrieves a list of bridges from the cluster
The following example shows the response with a list of bridges from the cluster:
# The API:
/api/storage/bridges
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/bridges" -H "accept: application/hal+json"
# The response:
"records": [
"wwn": "2000001086a18100",
"name": "ATTO_2000001086a18100",
"href": "/api/storage/bridges/2000001086a18100"
"wwn": "2000001086a18380",
"name": "ATTO_2000001086a18380",
"href": "/api/storage/bridges/2000001086a18380"
"num_records": 2,
"href": "/api/storage/bridges/"
2) Retrieves a specific bridge from the cluster
The following example shows the response of the requested bridge. If there is no bridge with the requested wwn, an error is returned.
# The API:
/api/storage/bridges/{wwn}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/bridges/2000001086a18100" -H "accept: application/hal+json"
# The response:
"chassis_throughput_state": "ok",
"dram_single_bit_error_count": 0,
"firmware_version": "3.10 007A",
"ip_address": "10.226.57.178",
"security_enabled": false,
"monitoring_enabled": true,
"model": "FibreBridge 7500N",
"state": "ok",
"managed_by": "in_band",
"serial_number": "FB7500N102450",
"symbolic_name": "RTP-FCSAS02-41KK10",
"vendor": "atto",
"last_reboot": {
"reason": {
"message": "Reason: \"FirmwareRestart Command\".",
"code": "39321683"
"time": "2020-12-09T00:47:58-05:00"
"paths": [
"name": "0e",
"node": {
"name": "sti8080mcc-htp-005",
"uuid": "ecc3d992-3a86-11eb-9fab-00a0985a6024",
"href": "/api/cluster/nodes/ecc3d992-3a86-11eb-9fab-00a0985a6024"
"href": "/api/storage/ports/ecc3d992-3a86-11eb-9fab-00a0985a6024/0e"
"target_port": {
"wwn": "2100001086a18380"
"temperature_sensor": {
"name": "Chassis Temperature Sensor",
"minimum": 0,
"maximum": 90,
"reading": 54,
"state": "ok"
"fc_ports": [
"id": 1,
"state": "online",
"enabled": true,
"negotiated_data_rate": 8,
"configured_data_rate": 8,
"conn_mode": "ptp",
"data_rate_capability": 16,
"wwn": "2100001086a18100",
"peer_wwn": "0000000000000000",
"sfp": {
"vendor": "FINISAR CORP.",
"serial_number": "UW106SA",
"part_number": "FTLF8529P3BCV",
"id": 2,
"state": "online",
"enabled": true,
"negotiated_data_rate": 16,
"configured_data_rate": 16,
"conn_mode": "ptp",
"wwn": "2200001086a18100",
"sfp": {
"serial_number": "UW1072B",
"power_supply_units": [
"name": "A",
"state": "ok"
"name": "B",
"state": "ok"
"sas_ports": [
"id": 1,
"state": "online",
"enabled": true,
"data_rate_capability": 12,
"negotiated_data_rate": 6,
"wwn": "5001086000a18100",
"phy_1": {
"state": "online"
"phy_2": {
"state": "online"
"phy_3": {
"state": "online"
"phy_4": {
"state": "online"
"cable": {
"vendor": "Molex Inc.",
"serial_number": "618130935",
"technology": "Passive Copper 5m ID:00",
"part_number": "112-00431"
"state": "offline",
"enabled": false,
"negotiated_data_rate": 0,
"wwn": "5001086000a18104",
"phy_1": {
"state": "offline"
"phy_2": {
"state": "offline"
"phy_3": {
"state": "offline"
"phy_4": {
"state": "offline"
"state": "offline",
"enabled": false,
"wwn": "5001086000a18108",
"phy_1": {
"state": "offline"
"phy_2": {
"state": "offline"
"phy_3": {
"state": "offline"
"phy_4": {
"state": "offline"
"state": "offline",
"enabled": false,
"wwn": "5001086000a1810c",
"phy_1": {
"state": "offline"
"phy_2": {
"state": "offline"
"phy_3": {
"state": "offline"
"phy_4": {
"state": "offline"
