Manage storage bridges
Access detailed storage bridge information within your cluster using the storage bridge GET API endpoints. Use these endpoints to retrieve lists of bridges or specific bridge details as needed for monitoring and management tasks.
Retrieving storage bridge information
The storage bridge GET API retrieves all of the bridges in the cluster.
1) Retrieves a list of bridges from the cluster
The following example shows the response with a list of bridges from the cluster:
# The API:
/api/storage/bridges
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/bridges" -H "accept: application/hal+json"
# The response:
"records": [
"wwn": "2000001086a18100",
"name": "ATTO_2000001086a18100",
"href": "/api/storage/bridges/2000001086a18100"
"wwn": "2000001086a18380",
"name": "ATTO_2000001086a18380",
"href": "/api/storage/bridges/2000001086a18380"
"num_records": 2,
"href": "/api/storage/bridges/"
2) Retrieves a specific bridge from the cluster
The following example shows the response of the requested bridge. If there is no bridge with the requested wwn, an error is returned.
# The API:
/api/storage/bridges/{wwn}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/bridges/2000001086a18100" -H "accept: application/hal+json"
# The response:
"chassis_throughput_state": "ok",
"dram_single_bit_error_count": 0,
"firmware_version": "3.10 007A",
"ip_address": "10.226.57.178",
"security_enabled": false,
"monitoring_enabled": true,
"model": "FibreBridge 7500N",
"state": "ok",
"managed_by": "in_band",
"serial_number": "FB7500N102450",
"symbolic_name": "RTP-FCSAS02-41KK10",
"vendor": "atto",
"last_reboot": {
"reason": {
"message": "Reason: \"FirmwareRestart Command\".",
"code": "39321683"
"time": "2020-12-09T00:47:58-05:00"
"paths": [
"name": "0e",
"node": {
"name": "sti8080mcc-htp-005",
"uuid": "ecc3d992-3a86-11eb-9fab-00a0985a6024",
"href": "/api/cluster/nodes/ecc3d992-3a86-11eb-9fab-00a0985a6024"
"href": "/api/storage/ports/ecc3d992-3a86-11eb-9fab-00a0985a6024/0e"
"target_port": {
"wwn": "2100001086a18380"
"temperature_sensor": {
"name": "Chassis Temperature Sensor",
"minimum": 0,
"maximum": 90,
"reading": 54,
"state": "ok"
"fc_ports": [
"id": 1,
"state": "online",
"enabled": true,
"negotiated_data_rate": 8,
"configured_data_rate": 8,
"conn_mode": "ptp",
"data_rate_capability": 16,
"wwn": "2100001086a18100",
"peer_wwn": "0000000000000000",
"sfp": {
"vendor": "FINISAR CORP.",
"serial_number": "UW106SA",
"part_number": "FTLF8529P3BCV",
"id": 2,
"state": "online",
"enabled": true,
"negotiated_data_rate": 16,
"configured_data_rate": 16,
"conn_mode": "ptp",
"wwn": "2200001086a18100",
"sfp": {
"serial_number": "UW1072B",
"power_supply_units": [
"name": "A",
"state": "ok"
"name": "B",
"state": "ok"
"sas_ports": [
"id": 1,
"state": "online",
"enabled": true,
"data_rate_capability": 12,
"negotiated_data_rate": 6,
"wwn": "5001086000a18100",
"phy_1": {
"state": "online"
"phy_2": {
"state": "online"
"phy_3": {
"state": "online"
"phy_4": {
"state": "online"
"cable": {
"vendor": "Molex Inc.",
"serial_number": "618130935",
"technology": "Passive Copper 5m ID:00",
"part_number": "112-00431"
"state": "offline",
"enabled": false,
"negotiated_data_rate": 0,
"wwn": "5001086000a18104",
"phy_1": {
"state": "offline"
"phy_2": {
"state": "offline"
"phy_3": {
"state": "offline"
"phy_4": {
"state": "offline"
"state": "offline",
"enabled": false,
"wwn": "5001086000a18108",
"phy_1": {
"state": "offline"
"phy_2": {
"state": "offline"
"phy_3": {
"state": "offline"
"phy_4": {
"state": "offline"
"state": "offline",
"enabled": false,
"wwn": "5001086000a1810c",
"phy_1": {
"state": "offline"
"phy_2": {
"state": "offline"
"phy_3": {
"state": "offline"
"phy_4": {
"state": "offline"
