View security key managers
Overview
Retrieves the key manager keys on the give node. The following operations are supported:
GET
Retrieving key manager key-id information for a node
The following example shows how to retrieve key-ids present on a node for a key manager.
= The API:
GET /api/security/key-manager/{security_key_manager.uuid}/keys/{node.uuid}/key-ids
= The call:
curl -X GET 'https://+++<mgmt-ip>+++/api/f4f98a48-8a5c-c548-cd03-c6335f5803a8/keys/00000000-0000-0000-0000-000000000000/key-ids/000000000000000002000000000005009ad4da8fea2cafe2bed803078b780ebe0000000000000c01' -H 'accept: application/hal+json'+++</mgmt-ip>+++
= The response:
"security_key_manager": {
"uuid": "f4f98a48-8a5c-c548-cd03-c6335f5803a8"
"node": {
"uuid": "00000000-0000-0000-0000-000000000000"
"key_id": "000000000000000002000000000005009ad4da8fea2cafe2bed803078b780ebe0000000000000c01",
"svm": {
"name": "cluster-1"
"key_tag": "4d82cc07-f9e0-114e-55dc-82a224bea631",
"key_type": "vek",
"restored": false,
"key_store": "onboard",
"key_user": "datavs",
"key_manager": "onboard",
"key_store_type": "okm",
"encryption_algorithm": "XTS-AES-256",
"href": "/api/security/key-managers/f4f98a48-8a5c-c548-cd03-c6335f5803a8/keys/00000000-0000-0000-0000-000000000000/key-ids/000000000000000002000000000005009ad4da8fea2cafe2bed803078b780ebe0000000000000c01"
