View security key managers
Retrieve security key manager keys for a given node to manage encryption settings and maintain secure access within your environment.
Overview
Retrieves the key manager keys on the give node. The following operations are supported:
Get
Retrieving key manager key-id information for a node
The following example shows how to retrieve key-ids present on a node for a key manager.
# The API:
GET /api/security/key-managers/{security_key_manager.uuid}/keys/{node.uuid}/key-ids
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/key-managers/f4f98a48-8a5c-c548-cd03-c6335f5803a8/keys/00000000-0000-0000-0000-000000000000/key-ids/000000000000000002000000000005009ad4da8fea2cafe2bed803078b780ebe0000000000000c01' -H 'accept: application/hal+json'
# The response:
"security_key_manager": {
"uuid": "f4f98a48-8a5c-c548-cd03-c6335f5803a8"
"node": {
"uuid": "00000000-0000-0000-0000-000000000000"
"key_id": "000000000000000002000000000005009ad4da8fea2cafe2bed803078b780ebe0000000000000c01",
"svm": {
"name": "cluster-1"
"key_tag": "vsim1",
"key_type": "vek",
"restored": false,
"key_store": "onboard",
"key_user": "datavs",
"key_manager": "onboard",
"key_store_type": "okm",
"encryption_algorithm": "XTS-AES-256",
"href": "/api/security/key-managers/f4f98a48-8a5c-c548-cd03-c6335f5803a8/keys/00000000-0000-0000-0000-000000000000/key-ids/000000000000000002000000000005009ad4da8fea2cafe2bed803078b780ebe0000000000000c01"
Retrieving key manager key-id information of a specific key-type for a node
The following example shows how to retrieve key-ids of a specific key-type present on a node for a key manager.
= The API:
GET /api/security/key-manager/{security_key_manager.uuid}/keys/{node.uuid}/key-ids
= The call:
curl -X GET "https://+++<mgmt-ip>+++/api/security/key-managers/7c179931-044b-11ed-b7cd-005056bbc535/keys/44dac31e-0449-11ed-b7cd-005056bbc535/key-ids?key_type=nse_ak&return_records=true&return_timeout=15" -H "accept: application/json"+++</mgmt-ip>+++
= The response:
"records": [
"key_server": "10.225.89.34:5696",
"key_id": "000000000000000002000000000001003d5c5f8c497e8e36aa80566e08749a3d0000000000000000",
"key_type": "nse_ak"
"key_id": "00000000000000000200000000000100c2dce9a3a15aeb8480db8d49c17d056c0000000000000000",
"num_records": 2
