REST API reference
View security key managers
Retrieve security key manager keys on a specified node to manage encryption and access control. Use these endpoints to view key identifiers and details for secure data operations.
Overview
Retrieves the key manager keys on the give node. The following operations are supported:
  • Get
Retrieving key manager key-id information for a node
The following example shows how to retrieve key-ids present on a node for a key manager.
# The API:
GET /api/security/key-managers/{security_key_manager.uuid}/keys/{node.uuid}/key-ids
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/key-managers/f4f98a48-8a5c-c548-cd03-c6335f5803a8/keys/00000000-0000-0000-0000-000000000000/key-ids/000000000000000002000000000005009ad4da8fea2cafe2bed803078b780ebe0000000000000c01' -H 'accept: application/hal+json'
# The response:
  "security_key_manager": {
    "uuid": "f4f98a48-8a5c-c548-cd03-c6335f5803a8"
  "node": {
    "uuid": "00000000-0000-0000-0000-000000000000"
  "key_id": "000000000000000002000000000005009ad4da8fea2cafe2bed803078b780ebe0000000000000c01",
  "svm": {
    "name": "cluster-1"
  "key_tag": "vsim1",
  "key_type": "vek",
  "restored": false,
  "key_store": "onboard",
  "key_user": "datavs",
  "key_manager": "onboard",
  "key_store_type": "okm",
  "encryption_algorithm": "XTS-AES-256",
      "href": "/api/security/key-managers/f4f98a48-8a5c-c548-cd03-c6335f5803a8/keys/00000000-0000-0000-0000-000000000000/key-ids/000000000000000002000000000005009ad4da8fea2cafe2bed803078b780ebe0000000000000c01"
Retrieving key manager key-id information of a specific key-type for a node
The following example shows how to retrieve key-ids of a specific key-type present on a node for a key manager.
= The API:
GET /api/security/key-manager/{security_key_manager.uuid}/keys/{node.uuid}/key-ids
= The call:
curl -X GET "https://+++<mgmt-ip>+++/api/security/key-managers/7c179931-044b-11ed-b7cd-005056bbc535/keys/44dac31e-0449-11ed-b7cd-005056bbc535/key-ids?key_type=nse_ak&return_records=true&return_timeout=15" -H "accept: application/json"+++</mgmt-ip>+++
= The response:
  "records": [
      "key_server": "10.225.89.34:5696",
      "key_id": "000000000000000002000000000001003d5c5f8c497e8e36aa80566e08749a3d0000000000000000",
      "key_type": "nse_ak"
      "key_id": "00000000000000000200000000000100c2dce9a3a15aeb8480db8d49c17d056c0000000000000000",
  "num_records": 2
