REST API reference
Delete an export policy client
Removes an export policy client to manage or update access permissions for your storage resources.
HTTP method and endpoint
DELETE /protocols/nfs/export-policies/{policy.id}/rules/{index}/clients/{match}
Introduced in
ONTAP 9.6
Usage notes
Deletes an export policy client
  • vserver export-policy rule remove-clientmatches
policy.id
integer
path
True
Export Policy ID
index
integer
path
True
Export Rule Index
match
string
path
True
Export Client Match
return_records
boolean
query
False
  • Default value:
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1703954
Export policy does not exist
1704036
Invalid clientmatch: missing domain name
1704037
Invalid clientmatch: missing network name
1704038
Invalid clientmatch: missing netgroup name
1704039
Invalid clientmatch
1704040
Invalid clientmatch: address bytes masked out by netmask are non-zero
1704041
Invalid clientmatch: address bytes masked to zero by netmask
1704042
Invalid clientmatch: too many bits in netmask
1704043
Invalid clientmatch: invalid netmask
1704044
Invalid clientmatch: invalid characters in host name
1704045
Invalid clientmatch: invalid characters in domain name
1704050
Invalid clientmatch: the clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported
1704052
Warning: Not removing any strings from the clientmatch field for ruleindex. None of the match strings were found in the clientmatch list
1704064
Clientmatch host name too long
1704065
Clientmatch domain name too long
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
