Delete an export policy client
DELETE /protocols/nfs/export-policies/{policy.id}/rules/{index}/clients/{match}
Introduced In: 9.6
Deletes an export policy client
Related ONTAP commands
vserver export-policy rule remove-clientmatches
Learn more
policy.id  |
integer  |
path  |
True  |
Export Policy ID  |
index  |
integer  |
path  |
True  |
Export Rule Index  |
match  |
string  |
path  |
True  |
Export Client Match  |
return_records  |
boolean  |
query  |
False  |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703954  |
Export policy does not exist  |
1704036  |
Invalid clientmatch: missing domain name  |
1704037  |
Invalid clientmatch: missing network name  |
1704038  |
Invalid clientmatch: missing netgroup name  |
1704039  |
Invalid clientmatch  |
1704040  |
Invalid clientmatch: address bytes masked out by netmask are non-zero  |
1704041  |
Invalid clientmatch: address bytes masked to zero by netmask  |
1704042  |
Invalid clientmatch: too many bits in netmask  |
1704043  |
Invalid clientmatch: invalid netmask  |
1704044  |
Invalid clientmatch: invalid characters in host name  |
1704045  |
Invalid clientmatch: invalid characters in domain name  |
1704050  |
Invalid clientmatch: the clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported  |
1704054  |
Invalid clientmatch: invalid characters in netgroup name. Valid characters for a netgroup name are 0-9, A-Z, a-z, ".", "_" and "-"  |
1704064  |
Clientmatch host name too long  |
1704065  |
Clientmatch domain name too long  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
