Deletes an export policy client
learn more
doc /protocols/nfs/export-policies](#docs-nas-protocols_nfs_export-policies)
DELETE /protocols/nfs/export-policies/{policy.id}/rules/{index}/clients/{match}
Introduced In: 9.6
Related ONTAP commands
vserver export-policy rule remove-clientmatches
Learn more
policy.id |
integer |
path |
True |
Export Policy ID |
index |
integer |
path |
True |
Export Rule Index |
match |
string |
path |
True |
Export Client Match |
return_records |
boolean |
query |
False |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703954 |
Export policy does not exist |
1704036 |
Invalid clientmatch: missing domain name |
1704037 |
Invalid clientmatch: missing network name |
1704038 |
Invalid clientmatch: missing netgroup name |
1704039 |
Invalid clientmatch |
1704040 |
Invalid clientmatch: address bytes masked out by netmask are non-zero |
1704041 |
Invalid clientmatch: address bytes masked to zero by netmask |
1704042 |
Invalid clientmatch: too many bits in netmask |
1704043 |
Invalid clientmatch: invalid netmask |
1704044 |
Invalid clientmatch: invalid characters in host name |
1704045 |
Invalid clientmatch: invalid characters in domain name |
1704050 |
Invalid clientmatch: the clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported |
1704052 |
Warning: Not removing any strings from the clientmatch field for ruleindex. None of the match strings were found in the clientmatch list |
1704054 |
Invalid clientmatch: invalid characters in netgroup name. Valid characters for a netgroup name are 0-9, A-Z, a-z, ".", "_" and "-" |
1704064 |
Clientmatch host name too long |
1704065 |
Clientmatch domain name too long |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
