Delete the NFS configuration for an SVM
DELETE /protocols/nfs/services/{svm.uuid}
Introduced In: 9.6
Deletes the NFS configuration of an SVM.
Related ONTAP commands
vserver nfs delete
Learn more
svm.uuid  |
string  |
path  |
True  |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
3276916  |
Vserver is not running  |
3277008  |
NFS Kerberos must be disabled on all LIFs of Vserver before deleting the NFS configuration. When all LIFs are disabled, try the operation  |
3277009  |
NFS Kerberos realms associated with the Vserver are deleted  |
3277111  |
Internal error. Failed to remove NFS-specific security trace filter for Vserver  |
3277112  |
Internal error. Failed to modify the protocols field of a security trace filter for Vserver  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
