REST API reference
Delete NFS configuration for an SVM
Deletes the NFS configuration of a storage virtual machine (SVM) when you need to remove NFS settings that are no longer required.
HTTP method and endpoint
DELETE /protocols/nfs/services/{svm.uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes the NFS configuration of an SVM.
  • vserver nfs delete
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
3276916
Vserver is not running
3277008
NFS Kerberos must be disabled on all LIFs of Vserver before deleting the NFS configuration. When all LIFs are disabled, try the operation
3277009
NFS Kerberos realms associated with the Vserver are deleted
3277111
Internal error. Failed to remove NFS-specific security trace filter for Vserver
3277112
Internal error. Failed to modify the protocols field of a security trace filter for Vserver
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
