Deletes the nfs configuration of an svm
learn more
doc /protocols/nfs/services](#docs-nas-protocols_nfs_services)
DELETE /protocols/nfs/services/{svm.uuid}
Introduced In: 9.6
Deletes the NFS configuration of an SVM.
Related ONTAP commands
vserver nfs delete
Learn more
svm.uuid |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
3276916 |
Vserver is not running |
3277008 |
NFS Kerberos must be disabled on all LIFs of Vserver before deleting the NFS configuration. When all LIFs are disabled, try the operation |
3277009 |
NFS Kerberos realms associated with the Vserver are deleted |
3277111 |
Internal error. Failed to remove NFS-specific security trace filter for Vserver |
3277112 |
Internal error. Failed to modify the protocols field of a security trace filter for Vserver |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
