Delete a primary key server
Deletes a primary key server, removing its configuration and access from the system. Use this operation when you need to remove a server that is no longer required for key management tasks.
HTTP method and endpoint
DELETE /security/key-managers/{uuid}/key-servers/{server}
Introduced in
ONTAP 9.6
Optional parameters:
force- Bypass Out of Quorum checks wehn deleting a primary key server. This flag is set to "false" by default.
Related ONTAP commands
security key-manager external remove-servers
uuid |
string |
path |
True |
External key manager UUID |
server |
string |
path |
True |
Primary key server configured in the external key manager. |
force |
boolean |
query |
False |
Set the force flag to "true" to bypass out of quorum checks when removing a primary key server.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536600 |
Cannot remove a key server while a node is out quorum. |
65536700 |
The key server contains keys that are currently in use and not available from any other configured key server in the SVM. |
65536822 |
Multitenant key management is not supported in the current cluster version. |
65536824 |
Multitenant key management is not supported in MetroCluster configurations. |
65536828 |
External key management is not enabled for the SVM. |
65536843 |
The key management server is not configured for the SVM. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
