REST API reference
Delete a primary key server
Deletes a primary key server when you need to remove it from your configuration.
HTTP method and endpoint
DELETE /security/key-managers/{uuid}/key-servers/{server}
Introduced in
ONTAP 9.6
Usage notes
Deletes a key server.
  • security key-manager external remove-servers
uuid
string
path
True
External key manager UUID
server
string
path
True
Key server configured in the external key manager.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
65536700
The key server contains keys that are currently in use and not available from any other configured key server in the SVM.
65536822
Multitenant key management is not supported in the current cluster version.
65536824
Multitenant key management is not supported in MetroCluster configurations.
65536828
External key management is not enabled for the SVM.
65536843
The key management server is not configured for the SVM.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
