REST API reference
Delete a primary key server
Deletes a primary key server, which is useful when you need to remove outdated or unnecessary key server configurations from your system.
HTTP method and endpoint
DELETE /security/key-managers/{uuid}/key-servers/{server}
Introduced in
ONTAP 9.6
Optional parameters:
  • force - Bypass Out of Quorum checks when deleting a primary key server. This flag is set to "false" by default.
  • security key-manager external remove-servers
uuid
string
path
True
External key manager UUID
server
string
path
True
Primary key server configured in the external key manager.
force
boolean
query
False
Set the force flag to "true" to bypass out of quorum checks when removing a primary key server.
  • Introduced in: 9.11
  • Default value:
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
65536600
Cannot remove a key server while a node is out quorum.
65536700
The key server contains keys that are currently in use and not available from any other configured key server in the SVM.
65536824
Multitenant key management is not supported in MetroCluster configurations.
65536828
External key management is not enabled for the SVM.
65536843
The key management server is not configured for the SVM.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
