Delete a volume
Deletes a volume to free its blocks and return them to the containing aggregate. Use this endpoint when you want to remove a volume from your system permanently.
HTTP method and endpoint
DELETE /storage/volumes/{uuid}
Introduced in
ONTAP 9.6
Usage notes
If the UUID belongs to a volume, all of its blocks are freed and returned to its containing aggregate. If a volume is online, it is offlined before deletion. If a volume is mounted, unmount the volume by specifying the nas.path as empty before deleting it using the DELETE operation.
Optional parameters:
force- Bypasses the recovery-queue and completely removes the volume from the aggregate making it non-recoverable. By default, this flag is set to "false".
Related ONTAP commands
volume delete -
volume clone delete
uuid |
string |
path |
True |
Unique identifier of the volume. |
force |
boolean |
query |
False |
Set the force flag to "true" to bypass the recovery queue, making the deleted volume non-recoverable.
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
