REST API reference
Delete a volume
Deletes a volume, freeing its blocks and returning them to the containing aggregate. Use this operation when you need to remove a volume from your storage configuration.
HTTP method and endpoint
DELETE /storage/volumes/{uuid}
Introduced in
ONTAP 9.6
Usage notes
If the UUID belongs to a volume, all of its blocks are freed and returned to its containing aggregate. If a volume is online, it is offlined before deletion. If a volume is mounted, unmount the volume by specifying the nas.path as empty before deleting it using the DELETE operation.
Platform Specifics
  • Unified ONTAP: DELETE must be used to delete a volume.
Optional parameters:
  • force - Bypasses the recovery-queue and completely removes the volume from the aggregate making it non-recoverable. By default, this flag is set to "false".
  • volume delete
  • volume clone delete
uuid
string
path
True
Unique identifier of the volume.
force
boolean
query
False
Set the force flag to "true" to bypass the recovery queue, making the deleted volume non-recoverable.
  • Introduced in: 9.12
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
460770
[Job "jobid"] Job failed.
524615
Failed to delete volume because it has one or more clones.
917531
Cannot delete the root volume because the SVM contains other volumes.
918667
Volume "name" in SVM "svm.name" cannot be taken offline because it is configured to hold audit logs.
918693
918701
The specified operation on the volume endpoint is not supported on this platform.
13107349
Operation is only supported on flexible volumes and FlexGroup volumes.
65537463
Volume encryption keys (VEK) cannot be created or deleted for data Vserver \"{0}\". External key management has been configured for data Vserver \"{0}\" but ONTAP is not able to encrypt or decrypt with the key manager. Resolve the external key manager key issues at the key manager's portal before creating any new encrypted volumes.
65537529
Encrypted volumes cannot be created or deleted for Vserver \"{0}\" as a rekey operation for the vserver is in progress. Try creating the encrypted volume again after some time. If the problem persists, run the rekey operation again after some time.
65537600
Encrypted volumes cannot be created or deleted for Vserver \"{0}\" while the enabled keystore configuration is being switched. If a previous attempt to switch the keystore configuration failed, or was interrupted, the system will continue to prevent encrypted volume creation for Vserver \"{0}\". Use the \"security key-manager keystore enable\" command to re-run and complete the operation.
65539430
Cannot create or delete volumes on Vserver \"{0}\" while the keystore is being initialized. Wait until the keystore is in the active state, and rerun the volume operation.
65539431
Cannot create or delete volumes on Vserver \"{0}\" while the keystore is being disabled.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
