Delete a volume
Deletes a volume, removing all its blocks and freeing space in the containing aggregate. This operation is typically used to manage storage resources effectively by clearing unnecessary or obsolete data.
HTTP method and endpoint
DELETE /storage/volumes/{uuid}
Introduced in
ONTAP 9.6
Usage notes
If the UUID belongs to a volume, all of its blocks are freed and returned to its containing aggregate. If a volume is online, it is offlined before deletion. If a volume is mounted, unmount the volume by specifying the nas.path as empty before deleting it using the DELETE operation.
Related ONTAP commands
volume delete -
volume clone delete
uuid |
string |
path |
True |
Unique identifier of the volume. |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
