REST API reference
Retrieve history details for firmware update requests
Accesses the history details for firmware update requests to review past updates and their outcomes.
HTTP method and endpoint
GET /cluster/firmware/history
Introduced in
ONTAP 9.8
Usage notes
Retrieves the history details for firmware update requests.
end_time
string
query
False
Filter by end_time
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
fw_file_name
string
query
False
Filter by fw_file_name
update_status.worker.node.name
string
query
False
Filter by update_status.worker.node.name
update_status.worker.node.uuid
string
query
False
Filter by update_status.worker.node.uuid
update_status.worker.error.message
string
query
False
Filter by update_status.worker.error.message
update_status.worker.error.code
integer
query
False
Filter by update_status.worker.error.code
update_status.worker.state
string
query
False
Filter by update_status.worker.state
start_time
string
query
False
Filter by start_time
job.uuid
string
query
False
Filter by job.uuid
fw_update_state
string
query
False
Filter by fw_update_state
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[firmware_history]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "end_time": "2019-02-02T19:00:00Z",
      "fw_file_name": "all_disk_fw.zip",
      "fw_update_state": "string",
      "job": {
        "uuid": "string"
      "node": {
        "name": "node1",
      "start_time": "2019-02-02T19:00:00Z",
      "update_status": [
          "worker": {
            "error": {
              "code": 2228325,
              "message": "Cannot open local staging ZIP file disk_firmware.zip"
            "node": {
              "name": "node1",
            "state": "waiting_to_retry"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
node
_links
_links
name
string
uuid
string
firmware_history_update_state_error
code
integer
Code corresponding to the status message.
message
string
Error message returned when a firmware update job fails.
worker
error
node
node
state
string
The state of each worker that a node is controlling.
worker
worker
firmware_history
_links
_links
end_time
string
End time of this update request.
fw_file_name
string
Name of the firmware file.
fw_update_state
string
job
job_link
node
node
start_time
string
Start time of this update request.
update_status
array[firmware_history_update_state]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
