REST API reference
Retrieve history details for firmware update requests
Retrieves detailed historical records of firmware update requests for your cluster. Use this information to analyze update trends, troubleshoot issues, and verify system integrity over time.
HTTP method and endpoint
GET /cluster/firmware/history
Introduced in
ONTAP 9.8
Usage notes
Retrieves the history details for firmware update requests.
end_time
string
query
False
Filter by end_time
start_time
string
query
False
Filter by start_time
update_status.worker.state
string
query
False
Filter by update_status.worker.state
update_status.worker.node.name
string
query
False
Filter by update_status.worker.node.name
update_status.worker.node.uuid
string
query
False
Filter by update_status.worker.node.uuid
update_status.worker.error.message
string
query
False
Filter by update_status.worker.error.message
update_status.worker.error.code
integer
query
False
Filter by update_status.worker.error.code
job.uuid
string
query
False
Filter by job.uuid
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
fw_file_name
string
query
False
Filter by fw_file_name
fw_update_state
string
query
False
Filter by fw_update_state
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[firmware_history]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "end_time": "2019-02-02 19:00:00 +0000",
      "fw_file_name": "all_disk_fw.zip",
      "fw_update_state": "string",
      "job": {
        "uuid": "string"
      "node": {
        "name": "node1",
      "start_time": "2019-02-02 19:00:00 +0000",
      "update_status": [
          "worker": {
            "error": {
              "code": 2228325,
              "message": "Cannot open local staging ZIP file disk_firmware.zip"
            "node": {
              "name": "node1",
            "state": "waiting_to_retry"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
node
_links
_links
name
string
uuid
string
firmware_history_update_state_error
code
integer
Code corresponding to the status message.
message
string
Error message returned when a firmware update job fails.
worker
error
node
node
state
string
The state of each worker that a node is controlling.
worker
worker
firmware_history
_links
_links
end_time
string
End time of this update request.
fw_file_name
string
Name of the firmware file.
fw_update_state
string
job
job_link
node
node
start_time
string
Start time of this update request.
update_status
array[firmware_history_update_state]
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
