Retrieve history details for firmware update requests
Accesses firmware update request history details to review past updates and track changes in your system's firmware versions.
HTTP method and endpoint
GET /cluster/firmware/history
Introduced in
ONTAP 9.8
Usage notes
Retrieves the history details for firmware update requests.
Learn more
fw_update_state |
string |
query |
False |
Filter by fw_update_state |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
start_time |
string |
query |
False |
Filter by start_time |
job.uuid |
string |
query |
False |
Filter by job.uuid |
fw_file_name |
string |
query |
False |
Filter by fw_file_name |
update_status.worker.state |
string |
query |
False |
Filter by update_status.worker.state |
update_status.worker.error.code |
integer |
query |
False |
Filter by update_status.worker.error.code |
update_status.worker.error.message |
string |
query |
False |
Filter by update_status.worker.error.message |
update_status.worker.node.uuid |
string |
query |
False |
Filter by update_status.worker.node.uuid |
update_status.worker.node.name |
string |
query |
False |
Filter by update_status.worker.node.name |
end_time |
string |
query |
False |
Filter by end_time |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[firmware_history] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"end_time": "2019-02-02 14:00:00 -0500",
"fw_file_name": "all_disk_fw.zip",
"fw_update_state": "string",
"job": {
"uuid": "string"
"node": {
"name": "node1",
"start_time": "2019-02-02 14:00:00 -0500",
"update_status": [
"worker": {
"error": {
"code": 2228325,
"message": "Cannot open local staging ZIP file disk_firmware.zip"
"node": {
"name": "node1",
"state": "waiting_to_retry"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
job_link
_links |
uuid |
string |
node
_links |
name |
string |
uuid |
string |
firmware_history_update_state_error
code |
integer |
Code corresponding to the status message. |
message |
string |
Error message returned when a firmware update job fails. |
worker
error |
node |
state |
string |
The state of each worker that a node is controlling. |
worker |
firmware_history
_links |
end_time |
string |
End time of this update request. |
fw_file_name |
string |
Name of the firmware file. |
fw_update_state |
string |
job |
node |
start_time |
string |
Start time of this update request. |
update_status |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
