REST API reference
Retrieve ONTAP Mediator state and configuration
Accesses the current state and configuration of the ONTAP Mediator. This information helps you monitor and manage mediator operations.
HTTP method and endpoint
GET /cluster/mediators/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the mediator state and configuration.
uuid
string
path
True
  • format: uuid
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
dr_group
dr_group
DR group reference.
ip_address
string
The IP address of the mediator.
peer_cluster
peer_cluster
The peer cluster that the mediator service is used for.
peer_mediator_connectivity
string
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown.
port
integer
The REST server's port number on the mediator.
reachable
boolean
Indicates the connectivity status of the mediator.
uuid
string
The unique identifier for the mediator service.
  "dr_group": {
    "id": 0
  "ip_address": "10.10.10.7",
  "peer_cluster": {
        "href": "/api/resourcelink"
    "name": "cluster2",
    "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
  "peer_mediator_connectivity": "connected",
  "port": 31784,
  "reachable": 1,
  "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
dr_group
DR group reference.
id
integer
DR Group ID
string
self
peer_cluster
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
