Retrieve ONTAP Mediator state and configuration
GET /cluster/mediators/{uuid}
Introduced In: 9.8
Retrieves the mediator state and configuration.
uuid |
string |
path |
True |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
ip_address |
string |
The IP address of the mediator. |
peer_cluster |
The peer cluster that the mediator service is used for. |
port |
integer |
The REST server's port number on the mediator. |
reachable |
boolean |
Indicates the connectivity status of the mediator. |
uuid |
string |
The unique identifier for the mediator service. |
"ip_address": "10.10.10.7",
"peer_cluster": {
"href": "/api/resourcelink"
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"port": "31784",
"reachable": 1,
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
peer_cluster
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
