Retrieve configuration information for all SVM pairs in a MetroCluster configuration
Accesses configuration information for all SVM pairs in a MetroCluster setup to understand their current state and configuration details. This can help you manage and maintain your MetroCluster environment effectively.
HTTP method and endpoint
GET /cluster/metrocluster/svms
Introduced in
ONTAP 9.11
Usage notes
Retrieves configuration information for all pairs of SVMs in MetroCluster. REST /api/cluster/metrocluster/svms/?
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
cluster.name |
string |
query |
False |
Filter by cluster.name |
cluster.uuid |
string |
query |
False |
Filter by cluster.uuid |
configuration_state |
string |
query |
False |
Filter by configuration_state |
failed_reason |
string |
query |
False |
Filter by failed_reason |
partner_svm.name |
string |
query |
False |
Filter by partner_svm.name |
partner_svm.uuid |
string |
query |
False |
Filter by partner_svm.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[metrocluster_svm] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"cluster": {
"name": "cluster1",
"configuration_state": "string",
"failed_reason": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"partner_svm": {
"name": "string",
"uuid": "string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
Reason for SVM object replication failure.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
partner_svm
name |
string |
MetroCluster partner SVM name. |
uuid |
string |
MetroCluster partner SVM UUID. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
metrocluster_svm
_links |
cluster |
string |
Configuration state. |
failed_reason |
Reason for SVM object replication failure. |
partner_svm |
svm |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
