REST API reference
Retrieves configuration information for all pairs of svms in metrocluster rest /api/cluster/metrocluster/svms/?
GET /cluster/metrocluster/svms
Introduced In: 9.11
Retrieves configuration information for all pairs of SVMs in MetroCluster. REST /api/cluster/metrocluster/svms/?
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
cluster.name
string
query
False
Filter by cluster.name
cluster.uuid
string
query
False
Filter by cluster.uuid
configuration_state
string
query
False
Filter by configuration_state
failed_reason
string
query
False
Filter by failed_reason
partner_svm.name
string
query
False
Filter by partner_svm.name
partner_svm.uuid
string
query
False
Filter by partner_svm.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[metrocluster_svm]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "cluster": {
        "name": "cluster1",
      "configuration_state": "string",
      "failed_reason": {
        "arguments": [
            "code": "string",
            "message": "string"
        "code": "4",
        "target": "uuid"
      "partner_svm": {
        "name": "string",
        "uuid": "string"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
cluster
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
Reason for SVM object replication failure.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
partner_svm
name
string
MetroCluster partner SVM name.
uuid
string
MetroCluster partner SVM UUID.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
metrocluster_svm
_links
self_link
cluster
cluster
configuration_state
string
Configuration state.
failed_reason
error
partner_svm
partner_svm
svm
svm
error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
