REST API reference
Retrieve configuration information for all SVM pairs in a MetroCluster configuration
GET /cluster/metrocluster/svms
Introduced In: 9.11
Retrieves configuration information for all pairs of SVMs in MetroCluster. REST /api/cluster/metrocluster/svms/?
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
cluster.name
string
query
False
Filter by cluster.name
cluster.uuid
string
query
False
Filter by cluster.uuid
configuration_state
string
query
False
Filter by configuration_state
failed_reason
string
query
False
Filter by failed_reason
partner_svm.name
string
query
False
Filter by partner_svm.name
partner_svm.uuid
string
query
False
Filter by partner_svm.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 1
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[metrocluster_svm]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "cluster": {
        "name": "cluster1",
      "configuration_state": "string",
      "failed_reason": {
        "arguments": [
            "code": "string",
            "message": "string"
        "code": "4",
        "message": "entry doesn't exist"
      "partner_svm": {
        "name": "string",
        "uuid": "string"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
cluster
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
Reason for SVM object replication failure.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
partner_svm
name
string
MetroCluster partner SVM name.
uuid
string
MetroCluster partner SVM UUID.
svm
_links
_links
name
string
uuid
string
metrocluster_svm
_links
self_link
cluster
cluster
configuration_state
string
Configuration state.
failed_reason
error
partner_svm
partner_svm
svm
svm
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
