Retrieve NTP symmetric authentication keys
Retrieves NTP symmetric authentication keys to view the collection of keys available for use in securing time synchronization.
HTTP method and endpoint
GET /cluster/ntp/keys
Introduced in
ONTAP 9.7
Usage notes
Retrieves the collection of NTP symmetric authentication keys known by ONTAP that are uniquely indexed by an identifier.
Related ONTAP commands
cluster time-service ntp key show
Learn more
value |
string |
query |
False |
Filter by value |
digest_type |
string |
query |
False |
Filter by digest_type |
id |
integer |
query |
False |
Filter by id
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[ntp_key] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"digest_type": "sha1",
"id": 10,
"value": "da39a3ee5e6b4b0d3255bfef95601890afd80709"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ntp_key
_links |
digest_type |
string |
The type of cryptographic hash used to create and verify the NTP's message authentication code appended to each NTP packet header. |
id |
integer |
NTP symmetric authentication key identifier or index number (ID). This ID is included in the NTP cryptographic hash encoded header. |
value |
string |
A hexadecimal digit string that represents the cryptographic key that is shared with the remote NTP server. The current expected length is 40 characters. Use the cryptographic key and key ID to create a unique hash value used to authenticate the rest of the NTP data. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
