REST API reference
Retrieve the NTP symmetric authentication keys
Retrieves the collection of NTP symmetric authentication keys known by the system, each identified uniquely. This action is typically used to manage secure time synchronization configurations within your ONTAP environment.
HTTP method and endpoint
GET /cluster/ntp/keys
Introduced in
ONTAP 9.7
Usage notes
Retrieves the collection of NTP symmetric authentication keys known by ONTAP that are uniquely indexed by an identifier.
  • cluster time-service ntp key show
digest_type
string
query
False
Filter by digest_type
value
string
query
False
Filter by value
id
integer
query
False
Filter by id
  • Max value: 65535
  • Min value: 1
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[ntp_key]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "digest_type": "sha1",
      "id": 10,
      "value": "da39a3ee5e6b4b0d3255bfef95601890afd80709"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ntp_key
_links
_links
digest_type
string
The type of cryptographic hash used to create and verify the NTP's message authentication code appended to each NTP packet header.
id
integer
NTP symmetric authentication key identifier or index number (ID). This ID is included in the NTP cryptographic hash encoded header.
value
string
A hexadecimal digit string that represents the cryptographic key that is shared with the remote NTP server. The current expected length is 40 characters.
Use the cryptographic key and key ID to create a unique hash value used to authenticate the rest of the NTP data.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
