REST API reference
Retrieve an external NTP server configuration
GET /cluster/ntp/servers/{server}
Introduced In: 9.7
Retrieves the configuration of an external NTP server used by ONTAP.
  • cluster time-service ntp server show
server
string
path
True
NTP server host name, IPv4, or IPv6 address.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
authentication_enabled
boolean
Set NTP symmetric authentication on (true) or off (false).
key
ntp_key_reference
server
string
version
string
NTP protocol version for server. Valid versions are 3, 4, or auto.
      "href": "/api/resourcelink"
  "authentication_enabled": 1,
  "key": {
    "id": 10
  "server": "time.nist.gov",
  "version": "auto"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ntp_key_reference
_links
_links
id
integer
NTP symmetric authentication key identifier or index number (ID). This ID, the type of cryptographic hash, and the cryptographic hash value are all provided by the remote NTP server.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
